Locker Anytime Mod for Dummies 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsi, Nov 30, 2014.
  1. Nov 18, 2023 at 7:04 AM
    #801
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    It's a truck not a car...
    I'm assuming on asphalt you're talking about.
    It probably is depending on the tires you use but I wouldn't be trying to drift my Tacoma
    In the dirt all day long...ask me how I know:anonymous:
    Welcome to Taco world
  2. Nov 18, 2023 at 8:17 AM
    #802
    Whitwacker
    Whitwacker New Member
    Cole
    2011 Tacoma trd
    I mean off road the open diff doesn't let it have much fun and in the setting with auto lsd it doesn't let it slide out either. Wondered if this mod would allow for donuts in dirt/mud
  3. Nov 18, 2023 at 11:19 AM
    #803
    jsi
    jsi [OP] Well-Known Member
    native earthling
    When the locker any time mod is engaged the nannies are turned off.
    Thechief86 and TXpro4X4 like this.
  4. Nov 30, 2023 at 6:04 PM
    #804
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  5. Dec 1, 2023 at 12:59 PM
    #805
    jsi
    native earthling
    What this mod does is fool the truck into thinking its in 4 Lo and that lets you engage the locker. It's been 9 years since I researched my post, so my recollection is a bit fuzzy. But, I kind of remember not going down the fooling the truck road because it didn't feel right. I'm not a person that says because I did something it is the best way. (actually it makes me happy when someone shows me a better way to do things) If someone wanted to go for the fooling mod I'd love to see the outcome. It is certainly a simpler, non permanent mod.
    If you do go down the fooling mod path here is a link to the best wiring diagram I've seen. I'd want to understand what's going on before I started poking wires into the truck.
    https://www.tacomaworld.com/threads/2013-tacoma-electrical-wire-diagrams.278185/
    TAC1[QUOTED] likes this.
  6. Dec 1, 2023 at 3:47 PM
    #806
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    OK. Thank you
  7. Mar 12, 2024 at 7:38 PM
    #807
    ninja89
    ninja89 HUH?
    So I have been rocking this mod for 7-8ish years now with no problems…. Until today. looks like my rear locker, both traction control and abs lights are on.
    I haven’t checked codes yet, but will do once I get a good code reader.
    im wondering if the “diod” mod add on, is something that could fix my issue.
    4lo,4hi and 2 Hi are all working. But I noticed that the rear locker don’t seem to engage since the “rear locker” light is illuminated.
    . I’m curious if this was the reason for the diod on the write up.
    Thanks
    TXpro4X4 likes this.
  8. Mar 13, 2024 at 1:30 PM
    #808
    jsi
    native earthling
    The diode keep stray currents from damaging the electronics, but can't do anything if the damage is already done.
  9. Mar 13, 2024 at 2:04 PM
    #809
    ninja89
    ninja89 HUH?
    Do you know what the damages are? trying to figure out why these lights are on. im hopping its not to late.
  10. Mar 13, 2024 at 4:26 PM
    #810
    jsi
    native earthling
    My first guess would be that the locker is either engaged or thinks it is. If you've got a autoparts store like Autozone, Pep Boys, O'Reilly, etc they will loan you a scan tool.
  11. Mar 13, 2024 at 7:39 PM
    #811
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    What year is your truck? 2nd gen Tacos have zero OBD-II diagnostics for the 4WD system.
    I'm not sure whether 3rd gens have OBD-II diagnostics for 4WD.
  12. Mar 14, 2024 at 9:12 PM
    #812
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Fuck I need to put my shit in quit being such a dumbass
  13. May 31, 2024 at 6:39 PM
    #813
    Andrewman46
    Andrewman46 New Member
    Andrew
    Costa Mesa
    2015 Trd OR 4x4
    Attempt #2 went successful! Didnt read instructions properly the first attempt. All wire colors matched for 2015 or. Cant wait to try it out!
    TAC1 and jsi[OP] like this.
  14. Jun 1, 2024 at 6:27 AM
    #814
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Nice! Good luck & keep us posted.
  15. Jun 2, 2024 at 7:11 AM
    #815
    Josh07
    Josh07 New Member
    Josh
    07 Tacoma Trd offroad
    None
    I tried this mod yesterday on my 2007 TRD off-road. I used the omrod relay with the diode. The relay clicks and lights up when I push locker button but the light on the dash doesn’t light up and can’t hear the locker try to engage. Everything looks good. Any ideas on what my issue is? Thanks
  16. Jun 2, 2024 at 3:19 PM
    #816
    jsi
    native earthling
    I’m assuming the locker was working before, so the next step is to double check all of the connections. The light lighting and the relay clicking are good signs.
    Josh07[QUOTED] likes this.
  17. Jun 2, 2024 at 5:55 PM
    #817
    Josh07
    Josh07 New Member
    Josh
    None
    Yes sir. It was working. That’s my plan, to go back over everything. I’ll report back after I get the chance to go back through it. Thanks.
    jsi[OP] likes this.
  18. Jun 3, 2024 at 1:04 PM
    #818
    Andrewman46
    Andrew
    Costa Mesa
    2015 Trd OR 4x4
    Did some light trails on Sunday and everything worked great. I didn’t think it worked at first as no lights come on until the locker engaged but once you move forward or back a little it locks. It’s great all the aids turn off when the locker is engaged, no longer have to pull the abs fuse to have fun. I also have an extra relay from mouser if anyone wants it. Located in Newport Beach CA
    Josh07 and jsi[OP] like this.
  19. Jun 3, 2024 at 5:27 PM
    #819
    Josh07
    Josh07 New Member
    Josh
    None
    I found my issue with the mod. It was in my vampire clip. Once I fixed it, the locker engaged perfectly. Now I have a bigger problem. I can’t get my locker to disengage. I’ve been trying everything. I’ve torn my yard to shit. Been up hill, down hill, forward, backwards, dirt, gravel and pavement. Someone please help me!‍♂️
  20. Jun 5, 2024 at 8:27 AM
    #820
    Josh07
    Josh07 New Member
    Josh
    None
    Double checked, triple checked and checked again. Could not get the locker to disengage. Talked to an expert on the phone to double check what I had done. He said everything sounded right to him but he'd have to check it person. I was thinking maybe something was wrong with the actuator and was about to pull it. I decided to wire back like factory. The locker works perfect again while in 4Lo. No hesitation at all. Maybe something went wrong with the relay? Maybe it's the wrong one? Anyway, I'm back to where I started. The good news, nothing is torn up except for my yard.
