Locker Anytime Mod for Dummies 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsi, Nov 30, 2014.
  1. Sep 18, 2024 at 12:20 AM
    #841
    daddy_julz
    daddy_julz New Member
    JULZ
    La grande
    13 tacoma 4x4 off-road
    315/75/16 4.88 3/2 lift 550 static weight added
    QUESTION:
    "I've made a video on my Youtube channel showing the problem in detail and how to make your own relay w/ diode combination. If you don't want to make it yourself I've included links above where it can be purchased."
    WHATS THE LINK FOR THE RELAY W/ DIODE INCLUDED TO BE PURCHASED SO I DONT HAVE TO DO THAT CUSTOM STEP. OR I WOULD LIKE TO SUPPORT A LOCAL AND BUY ONE THAT HAS THE DIODE ALREADY INSTALLED
  2. Sep 18, 2024 at 4:34 PM
    #842
    jsi
    jsi [OP] Well-Known Member
    native earthling
    Here's the link from the first post
    https://www.mouser.com/ProductDetai...GAEpiMZZMsKEdP9slC0YVzLoqlJlno%2B28rChTsbwK0=
    I was the closest thing there was to buying local, USA, but there wasn't enough demand to make it worth doing.
    daddy_julz[QUOTED] likes this.
  3. Sep 18, 2024 at 4:54 PM
    #843
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have 19 spare diodes. I can solder them into a relay if you pay me for the relay and work. But i have no way to test it like @jsi , so its a risk to take. I will do my best if you choose me
    daddy_julz[QUOTED] and jsi[OP] like this.
  4. Sep 18, 2024 at 7:22 PM
    #844
    daddy_julz
    JULZ
    La grande
    dont know how this tread works but find me via insta @tacticaldetails if you have ocd with your work i trust it and will gladly pay the fee to support a fello
    fatfurious2 likes this.
  5. Sep 19, 2024 at 5:44 AM
    #845
    fatfurious2
    David
    Ashburn, VA
    I tried, but there were a few. Not sure which one to choose. My IG is @great_white_taco
    How does $30 sound? including the relay, diode, solder, and shipping to you
  6. Sep 21, 2024 at 8:52 AM
    #846
    fatfurious2
    David
    Ashburn, VA
    Going to see if my soldering works today :fingerscrossed:
  7. Sep 21, 2024 at 9:47 AM
    #847
    fatfurious2
    David
    Ashburn, VA
    @jsi so im getting ready to cut some wires.
    Have a question:
    i guess i dont have a correct vampire tap, but can I use a male/female spade on the violet wire (high up like your original post) and then add the Y cable to #2 and #3 (mine will be different because of my relay)?
    Or would it be possible to do with my T-tap that I also have pictured? Am I leaving the violet wire uncut ?
  8. Sep 21, 2024 at 9:50 AM
    #848
    fatfurious2
    David
    Ashburn, VA
    Wait, so violet is not cut at all? Correct?
  9. Sep 21, 2024 at 10:00 AM
    #849
    fatfurious2
    David
    Ashburn, VA
    I think Ive figured it out. Can use the t-tap splice. And put the spade on the Y that i created. Getting power from the violet, without cutting it.
    Im overly cautious, and asked my neighbor who is the same.
    3rd question, do i plug the factory plug back into the 4x4 ecu?
    EDIT: i just needed to keep reading. Its literally step 1 on the testing steps :bananadead:
    2001 4x4 likes this.
  10. Sep 21, 2024 at 10:35 AM
    #850
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    I also used a T-Tap on the purple wire and put the spade on the Y. Initially when I plugged the spade into the t-tap, the spade got pinned under the connector somehow and I wasn’t getting power to the locker. Had to pull it apart, realign it, then plug it back in. Worked then!
    Let us know if you get it working!
    fatfurious2[QUOTED] likes this.
  11. Sep 21, 2024 at 10:52 AM
    #851
    fatfurious2
    David
    Ashburn, VA
    Glad to have someone watching my progress. Had to take a gulp of confidence for those first few cuts!
    Current progress
    my relay has 2.6mm spades, so i had to get extra small connectors. We will know shortly if they work!
    2001 4x4[QUOTED] likes this.
  12. Sep 21, 2024 at 11:34 AM
    #852
    fatfurious2
    David
    Ashburn, VA
    I can hear the locker motor move and see the relay light up and make a small click!
    now for a short test drive!
    jsi[OP] and 2001 4x4[QUOTED] like this.
  13. Sep 24, 2024 at 12:05 PM
    #853
    fatfurious2
    David
    Ashburn, VA
    @daddy_julz got your relay in. Ill solder it after work today, and get it shipped tomorrow for you.
    If anyone else is interested I have one more relay, and plenty of diodes.
    jsi[OP] likes this.
  14. Feb 12, 2025 at 6:46 AM
    #854
    ddoystershack
    ddoystershack New Member
  15. Feb 12, 2025 at 9:16 AM
    #855
    jsi
    native earthling
    ddoystershack[QUOTED] likes this.
  16. Apr 1, 2025 at 5:49 PM
    #856
    Cjc3
    Cjc3 Member
    2007 Tacoma 4.0
    Awesome post! Doing this after a FJ t case swap. I will no longer have the 4x4 computer. Will this still work? Thanks in advance!
  17. Apr 2, 2025 at 1:44 AM
    #857
    6 gearT444E
    Deep South
    Herculiner Hootus
    absolutely
