locker anytime on 2wd?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LYNDENO, Mar 13, 2011.
  1. Mar 13, 2011 at 9:50 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    icon 2.5 with resi,all pro 3in. leaf pack ,flowmaster 40 series,35 watt hid 6000k,kicker L7 10,kenwood 1000w amp,
    any one know if you can do the locker anytime mod on a 2wd tacoma i hate how you have to be under 5mph
  2. Mar 13, 2011 at 9:52 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    already have just 4wd tacomas doing it
  3. Mar 13, 2011 at 9:55 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    what would that do by doing that, will it trick the speed control?
  4. Mar 13, 2011 at 9:57 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    makes sense thx alot
  5. Mar 13, 2011 at 9:57 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    1794 4WD FUNDRA/01TACO DCOR/05TACO DCOR/97 LX450/91 4R 4WD
    Ballin on a Budget
  6. Mar 13, 2011 at 9:58 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Wait you're a prerunner, I thought the locker doesn't have a speed limit?
    If you mean engaging the locker at over 5 mph, domt do it. You will grenade the rear end.
  7. Mar 13, 2011 at 9:59 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    witch harness is the 4wd ecu i know its behind the fuse box
  8. Mar 13, 2011 at 10:00 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    you have to be under 5 to engage it gets anowing
  9. Mar 13, 2011 at 10:03 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Once mine is engaged I usually leave it engaged. Better have it on then get stuck with it off
  10. Mar 13, 2011 at 10:04 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    i had a 01 prerunner and i was used to it , can be coming up on sunthing at 10mph and just click it in
  11. Mar 13, 2011 at 10:09 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    ok yea well my locker has been having problems and i thought that might fix it cus it seems like it thinks its going to fast to engage. i will be parked and push the button and the diff light and abs come on but it dusn't engage
  12. Mar 13, 2011 at 10:14 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    ive tryed the relay dusnt even click and ive checked all my fuses makes no sence
  13. Mar 13, 2011 at 10:22 PM
    LYNDENO
    LYNDENO [OP] Member
    riverside
    05 preRrunner
    Yea smart but I just want mine to work again I've tryed every thing with the engaging it and turning I just need to hitt up all the conections with my metor and find the broblem because sunthing must not be geting power
  14. Sep 30, 2011 at 3:23 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Confused . . . if I'm doing the locker anytime mod and I'm keeping the violet/white wire intact for the vehicle speed sense to the 4wd ECU, why is a switch needed? Does the relay I'd be adding for the mod bypass the vehicle speed sense and engage the locker regardless of vehicle speed? If so, then I can understand why you added a switch. Thanks for your reply.
  15. Nov 8, 2011 at 6:42 PM
    av8er2012
    av8er2012 Well-Known Member
    Nick
    Wasilla AK
    Impulse Red 05 TRD offroad
    icon coilovers, bilstein 5100 rear shocks, OME dakar leaf springs, ARB front bumper, Warn XD9000 winch, Heated mirror mod, Rear diff breather mod, fog light anytime mod, Alpine W203 headunit, boston SPZ front speakers, boston SL65 rear speakers, Jl Audio HD 750/1 and 600/4 amplifiers, JL Audio 10w6v2 sub in custom box white dash w/blue needles
    so in order to be able to engage the locker in 2hi and 4hi not just 4lo all you do still is cut the violet/white wire?
  16. Nov 8, 2011 at 7:20 PM
    av8er2012
    Nick
    Wasilla AK
    hey thanks a lot whippersnapper!!! that helped a lot!
