Locker in rear cause rough shifts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rwilhite07, Jul 8, 2010.
  1. Jul 8, 2010 at 1:18 PM
    rwilhite07
    rwilhite07 [OP] Well-Known Member
    Florida
    my new tacoma has a locker in the rear and ive never had a locker in any of my vehicles, ive owned 4 stick shifts before and never had a problem but when i drive this one the same as any other stick ive drove it seems to shift rough when the clutch is released and the shaft catches the rear end giving it power again( almost a snapping when the shaft catches) .. if you very slowly and smoothly release clutch and baby it, it shifts smooths. could this roughness be caused by the locker? or could it be tranny, clutch...?
  2. Jul 8, 2010 at 1:20 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    not the locker...
    how many miles on the truck. my 2010 shifted pretty rough for the first 4k miles until the clutch seemed to wear in
  3. Jul 8, 2010 at 1:24 PM
    rwilhite07
    Florida
    ok, and the truck has 180 but the motor tranny tcase and all only has 101k. was thinking maybe the clutch wasnt bled properly or something along those lines. it is pretty rough unless you really baby the clutch. as long as its not the tranny im happy and will get it figured out..
  4. Jul 8, 2010 at 1:25 PM
    rwilhite07
    Florida
    and shouldnt of said my "new" tacoma. its a 95 but just got it the other day..
  5. Jul 8, 2010 at 1:26 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    probably something to do with the clutch.
    unless the locker is engaged it wouldnt have anytihng to do with it
  6. Jul 8, 2010 at 1:26 PM
    Yoytoda
    Roland
    completely stock
    oh... misunderstood... you said your NEW tacoma... i dont think its the tranny. clutch is probably fine. i grabby clutch is better than a slipping one. try bleeding the clutch
  7. Jul 8, 2010 at 1:27 PM
    rwilhite07
    Florida
    will do thanks guys...
  8. Jul 8, 2010 at 1:30 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    It sounds like a typical locker scenario when you have one like a Detroit. When you release power to the wheels or press the clutch in it disengages and when you apply power it'll engage. Good lockers let you feel them working for you.
  9. Jul 8, 2010 at 1:32 PM
    rwilhite07
    Florida
    not sure what brand locker it is, it was there when i got the truck
  10. Jul 8, 2010 at 1:33 PM
    Yoytoda
    Roland
    completely stock
    your talking about an auto locker like a detroit locker.
    Im pretty sure he has trd with Elocker which is open unless you flip the switch.
  11. Jul 8, 2010 at 1:36 PM
    rwilhite07
    Florida
    its an aftermarket locker, mines not a trd and i dont have a push button to engage
  12. Jul 8, 2010 at 1:39 PM
    rwilhite07
    Florida
    also its got 456 gears which makes it a little more torquey than normal it seems when easing off the clutch. think it would do much better on a little bigger tires and these 33s
  13. Jul 8, 2010 at 1:40 PM
    Yoytoda
    Roland
    completely stock
    oh... still, in a straight line you shouldnt notice it when shifting
  14. Jul 8, 2010 at 1:43 PM
    rwilhite07
    Florida
    alright, will bleed my clutch later on and let yall know if that solves the issue..
  15. Jul 8, 2010 at 2:23 PM
    rwilhite07
    Florida
    is this the bleeder valve for clutch? never bled a clutch only brakes.
  16. Jul 8, 2010 at 2:35 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Always good to have a selectable locker!
