Locker Mod??? Please help
Discussion in 'Technical Chat' started by gjbonner, Apr 22, 2009.
  1. Apr 22, 2009 at 10:16 PM
    gjbonner
    gjbonner [OP] Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
  2. Apr 23, 2009 at 9:42 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    OEM (Original Equipment Manufacturer) = factory / 'stock' locker switch.
  3. Apr 23, 2009 at 9:57 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    :rofl:hahaha i never heard that before
  4. Apr 23, 2009 at 10:29 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Barney voice - " Hey keeyuds, I'm gonna be doin this too" very soon. 5100s on the way, AAL w/new ubolts in the house.
  5. Apr 23, 2009 at 10:38 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
  6. Apr 23, 2009 at 5:33 PM
    gjbonner
    Guy
    Northern Idaho
    That's awesome guys LMAO! Yeah I'm iin the Marine Corps and that is a phrase we use a lot "Break it down Barney style".
    So what i'm getting from this is that the OEM switch is just the button you push for the lockers by the steering wheel.
    Are the coil contacts that is referenced on the back of that switch?
    So I would need to run the wire from the ECU over to the Locker switch and then another one from the Locker switch to the wht/blk wire to be a ground?
    Can't wait to lift this next month! For those who are going to ask its Rhino Lined with Tuff Grip. Hey somebodys got to do it...Why not me?
  7. Apr 24, 2009 at 6:42 PM
    gjbonner
    Guy
    Northern Idaho
    Anyone, ...Bueller....Bueller....?
  8. Apr 24, 2009 at 7:07 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    You Rhino Lined the whole truck?
  9. Apr 24, 2009 at 7:20 PM
    gjbonner
    Guy
    Northern Idaho
    uhmmm yeah guilty as charged...u like? As for the thread i cant find anyone who can solve that last step completley for me...
  10. Apr 24, 2009 at 7:43 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    That is badass rhino lining the whole truck. rep added!
  11. Apr 24, 2009 at 9:14 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I don't have a locker, so I can't explain from experience with the mod. However, the two coils they are talking about are inside the relay. Most relays are SPST (single pole single throw). SPST relays have a single coil and a single switch inside the relay. The coil is connected to two terminals and the switch is connected to two terminals on the outside of the relay. When electrical current passes through the coil, it will activate the switch inside the relay. This allows a relatively low voltage and current to turn on/off a much higher voltage and current.
    A DPDT (double pole, double throw) relay can have one or two coils inside, and will always have two switches inside. The principle is the same. When current passes through the coil(s), the switches are activated. A single coil DPDT will activate both switches at the same time, while a dual coil DPDT can be configured to activate both switches together or separately.
    So....the two coil contacts they are talking about are the two terminals on the relay which connect to the coil inside.
    I hope this has helped rather than add to any confusion. BTW, I dig the rhino lining. It makes it look like primer. Pretty unique.
  12. Apr 25, 2009 at 7:40 AM
    gjbonner
    Guy
    Northern Idaho
    No that clears a lot up. And after you said that i reread the article and at the top iy shows an actual pic of a relay and off to the side it says "The coil contacts are generally turned a different direction for ease of identification." So it was nice that I missed that part! Your info cleared everything up thanks.
    As for the truck, once the lift is on I'll get it cleaned up and get some pics posted in a month or so. Then in July I should be up in Northern Idaho wheelin while i'm on vacation.
