Locker Mod. problem, stuck engaged
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DNahas, Feb 12, 2010.
  1. Feb 12, 2010 at 10:01 AM
    DNahas
    DNahas [OP] Well-Known Member
    Dallas
    09 DC 4x4 OR
    I have an 09 4x4 OR.
    I used the directions for the 278-218 relay from rat shack
    I did the locker mod turned it on in 2wd like it should. The problem is when I attempt to disengage the locker, it does not happen. The diff lock light is on. I can change from 2wd to 4wd hi and low.
    With the key in the ON position, engine off, you press the RR DIFF LOCK button, I hear relay click but NOT the electric motor on the diff.
    At this point I returned all of the connections into the 4wd ECU back to factory and checked the 4wd ECU fuse. I still have the same problem.
    I assume that I must have screwed up something with the locker, the actuator, the motor, or the limit switch.
    How can I manually disengage the locker?
  2. Feb 12, 2010 at 10:02 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Roll forward or back a bit?
  3. Feb 12, 2010 at 2:06 PM
    DNahas
    Dallas
    09 DC 4x4 OR
    Did that about a thousand times in the driveway!
    The good news is that its fixed, bad news is I am not sure why. I was checking EVERY fuse on the truck. Although I did not find any blown, I guess pulling them forced a reset on the ECU, pick one, that let the system figure out the diff was locked.
    I then went back to the locker mod configuration and all is working as intended.
  4. Feb 12, 2010 at 2:17 PM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    It's not necessarily just rolling back and forth but you sometimes have to have the front wheels turned just slightly to allow the rear wheels to turn at slightly different rates to get everything aligned just right. Only have to roll a couple of feet slowly. I had my locker stayed engaged (I haven't done the locker mod yet) until I turned the front wheels just a touch.
  5. Feb 15, 2010 at 8:44 AM
    DNahas
    Dallas
    09 DC 4x4 OR
    That didn't work either. I did much more than turn the wheels and move a little. I am sure I'll get flamed for this, and I am aware of the damage it causes, but I drove around the block and in and out of the drive way.
    It was an electrical problem, not mechanical. The motor was not getting the signal to open the diff. b/c the ECU thought is was open.
  6. Feb 28, 2018 at 9:25 PM
    Jeff108
    Jeff108 Well-Known Member
    Jeffrey
    Redondo Beach , CA
    2013 Toyota Tacoma DCLB 4x4 TRD Sport Pyrite Mica / R.I.P 2009 Toyota Tacoma TRD O.R. 4x4 6 Speed Access Cab
    Nothing much yet, just an Snugtop high rise camper shell for now
    OP, I'm having the same exact issue right now.. I'm going to try to do as you stated. Unplug battery and all fuses and check them out to try to reset the ecu for 4wd. Is this what helped you?
