Locker mod to a sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MEKiter, Nov 9, 2009.
  1. Nov 9, 2009 at 3:46 PM
    MEKiter
    MEKiter [OP] Member
    Dan
    Portsmouth NH
    2010 BC LB 4X4 Sport
    Has anyone heard of putting in a locker to a sport model? I searched for it but didn't really see anything. It's just something that I'm thinking about. I'm sure the factory wiring is there it's just missing the switch and the locker equipment.
  2. Nov 9, 2009 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Wireing isnt there. AND...You need a different rear carrier too.
  3. Nov 9, 2009 at 3:49 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    that was easy!
  4. Nov 9, 2009 at 3:54 PM
    MEKiter
    MEKiter [OP] Member
    Dan
    Portsmouth NH
    Thats easy, and that sucks!
    Oh well. Maybe later on.
  5. Nov 9, 2009 at 4:28 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Try the 4 Low TRAC mod. It's better than a single locker, and it's free!
  6. Nov 9, 2009 at 7:25 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    explain...
    And chris, does that apply to the 09's? I thought you could get an ARB air locker for them since thier lim slip wasn't mechanical.
  7. Nov 9, 2009 at 7:27 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    dtrujillo63 installed front/rear ARB lockers, and new gears as well in his Sport
  8. Nov 9, 2009 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What Monkeyproof said. :)
  9. Nov 9, 2009 at 7:37 PM
    MEKiter
    MEKiter [OP] Member
    Dan
    Portsmouth NH
    I was thinking more of the factory locker. I figured that ARB would have an air locker. I thought that the factory wiring harness would be there to use and make it an easy clean install. But an ARB is an option. thanks
  10. Nov 9, 2009 at 10:34 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I'm interested in the factory locker too. Anything can be done its just a question of cost. I have an 09 dc lb sport. I too was hoping a part of the off-road package was in the truck so I could just add the missing pieces! There are some in the 4-runner community adding the factory lockers to vehicles not originally equipped with it. Search: retrofit electric locker for a pretty detailed write-up on one such conversion. Maybe just maybe, we can have it all!
  11. Nov 9, 2009 at 10:44 PM
    MonkeyProof
    SoCal- SGV
    not only would you need the electronics for the e-locker, you would also need the rear axle housing to accommodate the rear e-locker actuator/motor, the actuator/motor itself, and the 3rd member for the e-locker
    there are other viable options to a rear locker other then the toyota e-locker or the ARB that you should consider
  12. Nov 10, 2009 at 5:59 AM
    nelztaco
    Neil
    Levittown, PA
    Yes I know. I'm just saying that it is feasible to do this conversion and sometime soon someone is gonna have the resources and it will be done. Particularly if some of the wiring and stuff is already in the truck. If all you have to do is modify or change the rear chassis harness & you have a donor axle complete & you can buy a switch for the dash provided the wiring is already there... Its not that much of a stretch considering the mods I've seen on this forum. You guys cut off a factory cross-member for a 6 inch lift!!
  13. Nov 10, 2009 at 6:11 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    saying that you have a e-locked complete housing in hand could you get the wiring from 12voltguy.com and have it work properly? just throwing out ideas....
    Link to 12voltguy wiring
  14. Nov 10, 2009 at 6:45 AM
    nelztaco
    Neil
    Levittown, PA
    Sorry Baby Neil was crying had to settle him down. I was thinking more along the lines of using the factory components. But that might work as well. I just find it hard to believe that the off road package has its own dash cluster, its own dash harness etc. Starting with the 09 model even the limited slip diff is no longer exclusive to the sport model.
  15. Nov 10, 2009 at 6:50 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Starting with the '09s the LSD isn't an mechanical LSD. It's the brakes controlled by a computer.
    I'm not sure why you would try to install a factory locker- It's probably going to cost the same or less to install an ARB Air locker with OBA system in the stock axle. ::shrug::
  16. Nov 10, 2009 at 7:09 AM
    nelztaco
    Neil
    Levittown, PA
    I just think it is an excellent feature to add, and if it could be done that way why not. It has some safety features built in to it as well. I already know whats coming next: "Dude you shoulda bought the OR package". No, I bought the right truck. I love my truck. I love the look of the dclb. I love the color I chose. I just want to make it even more awesome than it already is!
  17. Nov 10, 2009 at 8:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Aftermarket ARB locker......
  18. Nov 10, 2009 at 8:19 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You could always do the old weld mod :)
  19. Nov 10, 2009 at 8:38 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OK, say you have the switch & score the whole axle/3rd member from a junkyard. And at the junkyard you start at the axle & get the wiring harness too. Now, what are we lookin at for it to work besides just putting the axle on the truck, wiring the harness to the switch & to whatever power it needs & possibly changing the gearing?
  20. Nov 10, 2009 at 9:43 AM
    nelztaco
    Neil
    Levittown, PA
    I haven't researched it that far but if you do a search outside of this forum for retrofit electric locker someone with a 4runner completed something similar.
