Locker or ReGear??
Discussion in 'General Automotive' started by sandman427, Jan 18, 2010.
  1. Jan 18, 2010 at 11:35 PM
    sandman427
    sandman427 [OP] KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    Ay i needed some help decided if i wanted to re-gear or get a locker for the truck... im running 285s and i have a 3 day commute to Northridge its about 45mins or 50 miles from where I live.... I do offroad.... but im trying to figure out what would be a necessity right now...?? Im a little worried about the tranny from the drive with the bigger tires.... and i would like to take care of the truck as much as possible... i guess what im saying will the 33s hurt the truck in the long run...??? Or will i be ok..?? and i would like the locker to kinda compensate for not having 4WD.... if u guys can give me some ideas that would be coo... thanks
  2. Jan 18, 2010 at 11:47 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    I have not herd of any problems with our trannys from running 285s without a regear, but i would just save up and do the locker and regear at the same time.
  3. Jan 18, 2010 at 11:58 PM
    sandman427
    Amir
    BAMF TACO!!
    thanks im just worried about the longrun.... is it even worth it to re gear...????
  4. Jan 19, 2010 at 4:20 AM
    Brunes
    Brunes abides.
    Rotorhead
    I would vote no it's not really worth it. You went from 31 or so inch tires to 33 or so. That is less than a 10% change.
    You CAN regear but I wouldn't worry too much about it. You probably want to talk to a gearing professional and get the low down on what changing your final drive gear will do. Because it'll reduce the wear on your transmission- but it'll also change your drive feeling- You may gain top end (lower RPMs are higher speed) but have a crappy start in first or vice versa....
    (Disclaimer- I am not a gearing guru....so I could be AFU)
  5. Jan 19, 2010 at 4:29 AM
    sandman427
    Amir
    BAMF TACO!!
    Really 10%..?? I thought it was more..?? Well if it's not that much then I should consider the locker then..??
  6. Jan 19, 2010 at 4:39 AM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    You're AFU. :D Regearing (to higher ratio gears) should give higher RPM and lower speed. I am not a gearing guru either...so maybe I'm AFU.
  7. Jan 19, 2010 at 4:57 AM
    Brunes
    Brunes abides.
    Rotorhead
    You changed tire size by 2 inches....that is less than a 10% change in tire size...and 10% change is where most folks feel you must regear.
    I'd do both at once if you are thinking about it....but you will save a little money if you don't regear.
    Either way....There are trade offs...and knowing what you are trading off before you just throw some new gears in there is key.
  8. Jan 19, 2010 at 6:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What locker are you putting in?
    If you're putting an ARB in - then you have to pay for a gearing install anyway and probably have to buy new gears regardless of what ratio they are (ARB is a carrier change and you have to buy gears that fit the ARB).
    I would say..... REGEAR!!!! It's not gonna hurt anything especially if you're getting the *power band* back to its original level. Not only that - but you'll enjoy the power when you step on the gas (it'll actually accelerate). You'll also get a slower crawl while in 4lo.
    Of all my years of offroading, I've never heard of transmissions failing or being 'worn out' due to regearing.
    Research around and find out what a lot of people are regearing to. 4.56 is a popular choice. I had 4.56 in my Jeep with 33's and then with 35's.
  9. Jan 19, 2010 at 6:38 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Probably a dumb question, but don't PreRunners come stock with a locker?
  10. Jan 19, 2010 at 8:21 AM
    AZCOMA
    AZCOMA where can't I go?
    Kacey
    Laveen
    05 Preunner sr5
    2.5 saw co's, n-fab bed cage rear tire mount,new head unit and 10"sub,285/75/16 nittos on M/T wheels,H.I.D.'s...The next mod is T.C. long travle kit,Deavers and glass all the way around.
    nope. trd or. trd s. sr5 all come different. locker, limited slip, and a full open diff.
  11. Jan 19, 2010 at 8:43 AM
    JDMcQ
    I was not aware of that, thank you.
  12. Jan 19, 2010 at 12:38 PM
    sandman427
    Amir
    BAMF TACO!!
    Thanks... I was looking at the arb one... But I wasn't aware that u can change gears at the same time..?? Does the arb come With 4.56 gears..?? The reason y i was worried was because of my 53 mile commute 3 days a week and the freeway I take has a lot of mountian and hills on the freeway...
  13. Jan 19, 2010 at 8:46 PM
    sandman427
    Amir
    BAMF TACO!!
    Bump.... I kinda want a few more opinions... Lol
  14. Jan 19, 2010 at 8:50 PM
    sandman427
    Amir
    BAMF TACO!!
    Oh and my ba janster I meant if the tranny would get worn out If I DIDNT regear.... Thanks again for the info y'all
  15. Jan 19, 2010 at 8:54 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I say save up and do both. But if You had to pick one go with regearing. If I regear it will be to 4.56
  16. Jan 19, 2010 at 8:57 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i would regear and lock it at the same time. either one is a costly proposition: arb locker with compressor and the changing the gears, because you have to do a decent amount of work to get those installed in the diff. while your doing one its most economical to do both at the same time.
    regearing returns (or makes closer) your stock power band due to the increase in tire diameter. people say that after the regear they feel as if the trucks engine works less or struggles less in order to do the same work, but with the downfall of your rpm's either being raised a few hundred or again returning close to the stock cruising rpm's at a given speed.
    so in turn what i mean by struggles less, it brings back the feeling of the off-the-lot-trucks performance
    i am in the same boat as you. i am trying to figure out if regearing my 4 banger is worth it while i install a lunch box locker in it in the coming couple months
  17. Jan 19, 2010 at 9:12 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Good mind! I think with your tires 4.56s are great!
  18. Jan 19, 2010 at 9:13 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    I agree. If your gonna be doing work on the differentials, just save up and do both. If it came down to it though, I would regear. I hate the power loss I suffered with 33's. Talk to Paul-HBMURPHY, I think he got some really good pricing on new gears.
  19. Jan 19, 2010 at 9:13 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I had 35's and then 33's on my 2001 Ranger and had 4.56's. I loved it. Made the truck quick too.
  20. Jan 19, 2010 at 9:16 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    haha. you got to it before I though you would.
