locker question???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mpoirier, Dec 8, 2010.
  1. Dec 8, 2010 at 8:42 AM
    mpoirier
    mpoirier [OP] Member
    Charlottesville, VA
    '08 tacoma trd off road
    rear tsb, 5100's at 1.75", weathertech floorliners, wet okole seat covers, 265/75 Goodyear wrangler authority
    Once the locker is engaged on my TRD offroad it will not disengage until i shift out of 4lo. should i be able to stay in 4lo and just push the locker button again to disengage? i figured i could stay in 4lo and engage/disengage by pushing the button to turn it on then pushing the button again to turn it off. i did drive for a little after pushing the button to disengage but it would not get out of the "locked" mode until i went into neutral and shifted back into 4hi.
  2. Dec 8, 2010 at 8:45 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Why are you in 4lo just out of curiosity not sure about your question owners manual may say though.
  3. Dec 8, 2010 at 8:49 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Yes, you should be able to switch on/off as needed. Does the light flash when you try to disengage it?
    Sometimes if it is not used much, it becomes a little sticky.
    Have you changed your diff oil as recommended?
  4. Dec 8, 2010 at 8:52 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Try driving slowly left and right when you disengage also.
  5. Dec 8, 2010 at 8:53 AM
    mpoirier
    Charlottesville, VA
    driving around in the woods when i went hunting. Was in 4lo because it was a muddy hill with a turn and wanted better control. was really in 4lo because the locker will only engage in 4lo. just trying to find out if once the locker is engaged if i can push the locker button again to disengage but remain in 4lo.
  6. Dec 8, 2010 at 8:55 AM
    mpoirier
    Charlottesville, VA
    thanks senna. thats what i thought. forget if it was flashing or not. will try again and see.
  7. Dec 8, 2010 at 11:42 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    As senna said, it should lock and unlock while you remain in L4. Any other time, you will only get the flashing light, but it isn't locked until the light stays on, solid.
    The idea of the locker is if you get stuck or cannot climb a slippery or rocky hill (in L4), then lock the rear... and once you are past the difficult place or unstuck, unlock it. Sure you can keep it locked longer, but Toyota doesn't want you to!
    In my 2 previous Tacomas, I used the rear locker MANY times... and it often had a bit of a time locking... and less of a problem unlocking. Now, with A-TRAC, I don't use the locker anymore... don't need to.
