Locker Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by SupraT, May 2, 2011.
  1. May 2, 2011 at 8:11 AM
    SupraT
    SupraT [OP] Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    So I was out wheeling this weekend and when I pushed my locker button all it did was flash and never did lock in, I tried going forward and reverse real slow and still no. My question is I had my truck in the shop a few weeks ago to get my drivers side rear axel seal fixed, Could they have done something to cause it not to lock in? Or should I be looking for something I might have broke?
  2. May 2, 2011 at 8:13 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Are you asking about the locker or switching into 4WD?
  3. May 2, 2011 at 8:19 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    The locker.
  4. May 2, 2011 at 8:27 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    going forward and reverse don't do much good unless you are also turning the wheel to rotate the axles...
    if they aren't lining up in the diff, going back and forth in a straight line with both axles turning at the same time won't help them line up to where they need to be to lock...
    so, stop, lock, roll, and turn...
    just like a dancer...
    hahaha
  5. May 2, 2011 at 8:31 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    HAHA yeah x2 if you roll forward or back and turn a little it should lock up if it's working properly or if your stuck and one tire is spinning.
  6. May 2, 2011 at 8:37 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    Some people have also suggested putting the truck in neutral, but turning a little will give you what your looking for
  7. May 2, 2011 at 8:40 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    I did turn back and forth while I was moving and nothing..
  8. May 2, 2011 at 8:45 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    try turning a complete circle...
    a slow moving donut...
    i have had a couple times before where turning the wheel side to side didn't lock right away either...
    turned the wheel left and made almost a full circle before the locker kicked in...
    i don't think the axle seal repair would impact it, unless of course the axle isn't back in there correctly, in which case, if you lifted the truck on jacks and put her in drive, the driver side would not turn at all...
  9. May 2, 2011 at 9:01 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    Ok i'll try that at lunch thank you.
  10. May 2, 2011 at 9:21 AM
    Bfoster133
    Blake
    you are at a stop right?
    i put it in neutral,foot off brake, press the button,, wait a few seconds, put on brake put it in drive and creep forward and it locks fine
    and if they didnt put the axel in right it would be pretty noticable, i dont think it would even drive because the tolerances in the diff are pretty tight and i dont know how it would fit without it being in right
  11. May 2, 2011 at 9:37 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    So I just went out in the parking lot and tried driving in a circle and turning back and forth and still no lock. I will try leaving my foot off the brake at lunch and see if that works. thanks
  12. May 2, 2011 at 9:40 AM
    JLee
    Jerry
    Benicia, CA
    Look at the axle and check if there are any plugs unplugged or wires cut. One more thing you are in 4lo or have the gray wire mod right?
  13. May 2, 2011 at 10:07 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    Ya I was in 4 low, havn't got around to do the gray wire mod yet.
  14. May 5, 2011 at 9:30 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    So has anyone actually had this same problem with it locking in? All connectors are hooked up and i have tried all suggestions. Just wondering where I should start troubleshooting at?
  15. May 5, 2011 at 8:39 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    take it back to the people who did the work and tell them they damaged your truck and they need to fix it free of charge. if they wont let them know that they just lost many good customers. then go to better buisness and report em!!! i have only done that in very bad situations
  16. May 6, 2011 at 5:54 AM
    green machine
    green machine Member
    Frank
    Washington, PA
    03 Tacoma
    I have the same issue. One guy here said to do the grey wire mod and see if that would get it to lock in. I havent had the time to get that done.
  17. May 6, 2011 at 6:35 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Pop lock and drop it?
  18. May 6, 2011 at 8:34 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    I am going to do the gray wire mod after work today and see if that makes a differance.
  19. May 7, 2011 at 7:57 AM
    blackheart
    blackheart Member
    michael
    alexander n.c.
    made the way i wonted it
    fabtec 2.5 3" coilover lift , ARB , 8k warn , uwc tool box . bushwachers cut out flairs , 2 12" memphis m3 subs , JBL amp , jennsen head unit .
    i'v had the same problm your talking about . i did the gray wire mod and i haven't had any more issues . but the indcater light does not fully light up . even if its in 4 lo . so it i tryed takeing the switch for the light out and held it in and the light never did come on fully . so i'm guessing the switch is gone to the bad . i would say thats yoou problem but if you was on concrete you would heard tire chrp .
    also food for thought after the gray wire mod . in 2wd it will do a nice donut if you got the power to kick it around lol .
  20. May 8, 2011 at 11:15 AM
    SupraT
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    So I did the gray wire mod today and nothing the light just blinks:confused:
