Locker question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBQ BOY, Jul 12, 2009.
  1. Jul 12, 2009 at 3:27 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you speaking from experience of installing an ARB in the tacoma?
    That might be true....
    But overall - carrier sizes are not created equal. Some carriers can be larger in size (deeper) than the stock carriers. The gears that install on those larger carriers can have the same ratio but would need to be shorter in size to fit in the same housing.
    Even if your stock original gears would fit - a gearing setup is very critical. If you don't get it right (especially with an ARB), you could totally destroy your gears AND the ARB.
  2. Jul 12, 2009 at 3:33 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think there is some talking past each other. You are both right.
    Jan said a gear setup is needed- Not necessarily brand new gears with a new ratio to anything. Gotta get the ARB carrier and the gears set up to fit properly- with the proper shims and what not...If I understand gear/differential building correctly (and I saw it on HorsepowerTV on time....I'm nearly a pro)
  3. Jul 12, 2009 at 3:48 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    No, I have not installed an ARB in a Tacoma myself. Although, I have researched this topic thoroughly, and have installed a handful of differential carriers in the past, along with R&P changes which will always require a full setup.
    You are spot on about carrier sizes not being equal, and this why I stated that at the least, new carrier shims will be required in order to get a proper setup. There are instances where you can get away with a perfectly good setup and only end up changing the carrier shims, and even some where that is not required (replacing an OEM carrier with an OEM carrier).
    The RD90 is designed to work with the factory gears and will simply replaces the OEM open differential carrier that comes in the Toyota "8.4" rears.
    I guess my original statement was misinterpreted, because I by no means meant that the possibility of a full setup would not be required.
  4. Jul 12, 2009 at 4:43 PM
    Janster
    Jandy
    Lancaster, PA
    No problem...we were talking the same thing in a couple different ways.
    All too often (without research) - people tend to think ARB's are a bolt-in & go installation. It's a lot more complicated than that, especially if you want it done right and to last.
  5. Jul 12, 2009 at 4:54 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i said also sweetheart. they were saying 4x4 OR's...so the OR prerunners ALSO come w/ it
  6. Jul 12, 2009 at 5:30 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I took my LSD out.. and popped the ARB in. So I'm fairly certain I know what I'm talking about. :D
  7. Jul 13, 2009 at 4:30 AM
    Janster
    Jandy
    Lancaster, PA
    OK....I'm not doubting that.
    Why don't you explain exactly what was involved & costs to have an ARB put in to the original poster (BBQ Boy).
    Your original post - doesn't exactly explain everything fully, IMO.
    The RD90 and a compressor is all you need.
    You don't need a gear set or a new third.
