Locker question
Discussion in 'Performance and Tuning' started by numbah57, Mar 28, 2010.
  1. Mar 28, 2010 at 11:48 PM
    numbah57
    numbah57 [OP] GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Hi guys, I was looking to buy a locker for my 2009 4cyl 5spd and i am kinda confused about how they lock, like does it lock when i put it in 4 wheel drive, or does it lock some other way thanks?? (for example say it was a detroit true trac)
  2. Mar 28, 2010 at 11:51 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    detroit is an auto locker so its not selectable. i think they use pos and neg loads to lock the gears up. by far the best lockers are arb which are selectable and use compressed air to lock. downside is they are very pricey
  3. Mar 28, 2010 at 11:54 PM
    numbah57
    kahai
    Maui, Hawaii
    Sorry for the idiotness but not selectable means that it is always locked?
  4. Mar 28, 2010 at 11:59 PM
    PrerunnerChris
    PrerunnerChris Go Big Or Go Home!
    SoCal
    06 PreRunner V6
    Yes
  5. Mar 29, 2010 at 12:01 AM
    numbah57
    kahai
    Maui, Hawaii
    alright thanks...are there any that are selectable that dont require on-board air?
  6. Mar 29, 2010 at 12:04 AM
    AZtacoma05
    AZtacoma05 Well-Known Member
    Austin, TX
    17 DCSB TRD Off Road
    Ox locker is actuated by a lever... but i dk if they have one to fit a tacoma? you could always swap out you're rear end for one with an E-locker. Why dont you want OBA?
  7. Mar 29, 2010 at 12:22 AM
    numbah57
    kahai
    Maui, Hawaii
    $$$$$$$$$$$$$$ or the lack there of
  8. Mar 29, 2010 at 12:23 AM
    numbah57
    kahai
    Maui, Hawaii
    I would love ARBs front and rear, i guess i should start selling drugs
  9. Mar 29, 2010 at 12:27 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It will always be active whether in 2 or 4.
    A Detroit locker stays locked until you turn. It will stay 'unlocked' when making a turn on the street for example and the outside wheel needs to rotate more than the inside wheel during normal driving.
    The bad thing about a Detroit is that it will lock based on the tension from the wheel basically staying locked. This can be bad! If you are driving on snowy highway and the tension eases up from a tire slipping the locker will engage and will spin you out of control in an instant. I imagine it might also wreak havoc on the VSC system but just a guess.
    The Detroit lockers are awesome and work great, but they are not ideal for daily drivers IMO. Off road use only.
    Go ARB, or look into an Electric Locker off totalled TRD OR (inferior but works fine for me)
  10. Mar 29, 2010 at 12:36 AM
    nvdeserted
    Reno, NV
    There is always the 'ghetto locker' in a pinch: press on the brakes and press on the gas!
  11. Mar 29, 2010 at 12:39 AM
    numbah57
    kahai
    Maui, Hawaii
    Guess Ill have to go with ARB, Now gotta get some cash!!
  12. Mar 29, 2010 at 12:45 AM
    nvdeserted
    Reno, NV
    There's good money in drugs... dibs on your ARB if you get caught :D
  13. Mar 29, 2010 at 1:12 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    lol
  14. Mar 29, 2010 at 12:11 PM
    numbah57
    kahai
    Maui, Hawaii
    Going wheeling today, Ill try the E-brake trick thingy
  15. Mar 29, 2010 at 12:31 PM
    AZtacoma05
    Austin, TX
    That only works if you have a limited slip diff though. So if you have a TRD Sport go for it!
  16. Mar 29, 2010 at 1:09 PM
    numbah57
    kahai
    Maui, Hawaii
    So its a no go for me then...no TRD
  17. Mar 29, 2010 at 2:08 PM
    nvdeserted
    Reno, NV
    I used to do it an an open (normal) diff on an old jeep before i ARB'd it, it's kind of hit or miss if it will help and should only be used as a last resort.
    I also used to jam large sticks through the spinning wheel (not while it was spinning) and lodge the it to the leaf springs basically, then the wheel I wanted to spin would work... until the stick broke.....
    Yes, I am the reason people at OSHA can't sleep at night... but I'm getting better.
  18. Mar 29, 2010 at 2:10 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Guys. He can do the yellow wire mod. You can trick your trucks skid control ECU into enabling TRAC while in 4x4 Lo.
    Yoytoda, has done amazing things with his truck.
    Yellow wire mod for 09-10 non-ATRAC Tacomas.
    Make your Tacoma unstoppable with Front and Rear LSD in 4Lo
    http://www.tacomaworld.com/forum/tec...4low-trac.html
