Locker vs. Limited Slip: LS better for Daily Driving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hartzpad, Jan 6, 2010.
  1. Jan 6, 2010 at 10:32 AM
    hartzpad
    hartzpad [OP] New Member
    I know that the locker is superior in poor traction situations (off road) and I want it, but you can't run the locker on dry pavement. This is where the limited slip seems like it would be better for every day driving on the pavement. In a truck with an empty bed, when you hit a patch of gravel or sand on the pavement or gas it around a corner, one wheel will generally spin like crazy. With a limited slip, you have less slippage and more traction.
    Same thing with wet pavement, one wheel will spin like crazy with an open diff but with a limited slip you can drive normally and get more traction. Am I crazy for wanting a TRD Sport for the limited slip instead of a TRD OR with a locker?
    Nothing is more annoying with trucks than needing to pull out quickly and having the inside tire spin needlessly when a limited slip would get you moving.
  2. Jan 6, 2010 at 10:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    All depends on the off roading you do. If you see alot of rocks, the locker would be great. If not, the LS is a good choice.
  3. Jan 6, 2010 at 10:38 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    x2
    If your mostly worried about street traction then go with the LSD, i got the locker since i need it for what i use my truck for and it also turns off the ABS which is sweet in the desert.
  4. Jan 6, 2010 at 10:45 AM
    hartzpad
    wish I could have both, because you can't beat a locker off-road. It would be cool to have an electro-magnetic locker which would allow you to use it as a limited slip by turning it down and it could fully lock at full power.
  5. Jan 6, 2010 at 10:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They have similar units, I just dont think they have them for the Taco yet.
  6. Jan 6, 2010 at 10:48 AM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    just put an air locker with a VSC truck ('09+)
    you get full electronic limited slip (not mechanical) and locker.
  7. Jan 6, 2010 at 11:20 AM
    10silvertaco
    10silvertaco Well-Known Member
    Brent
    no longer own Tacoma, now own 2011 Outback
    x2. I have TRD OR come with traction control. I don't have problem during rain. It does slip a little but traction kick in control. I believe VSC started in 2009+. Mine 2010.
  8. Jan 6, 2010 at 11:41 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    This Post really depends on what year your talking...
    All 09-10's have Trac/vsc/ Auto-Lsd w/ a button. Off-road also gets the locker and A-TRAC in 4lo.
    IF 05-08, then you decide Mech LSD in TRD Sport or Open diff w/ locker in 4lo on Off-road.
    Both have advantages/disadvantages that have been discussed to death, search away.
  9. Jan 6, 2010 at 11:42 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Locker FTMFW!!!
  10. Jan 6, 2010 at 2:27 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I don't really do any off-roading, and in general I'm happy I have the LSD. Particularly when there is snow on the roads, it is nice, because I wouldn't want to be driving around with the locker engaged on a regular basis.
  11. Jan 6, 2010 at 3:50 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    well u cant go fast with the locker either unless u do the locker mod.the lsd is perfect for say.........95% of the people.
  12. Jan 6, 2010 at 3:56 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    really i don't think you are supposed to drive around with the lsd engaged all the time either...if i recall it only works when in 2wd on the rear wheels...and it doesn't work when in 4wd..i may be wrong...i never really had a use for it...if i started sliping i just put it in 4wd
  13. Jan 6, 2010 at 3:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's a truck.... Even with an LSD.... if you gas it too hard while making a turn, I can qaurentee you'll have more fishtailing than you'll have traction.
  14. Jan 6, 2010 at 4:00 PM
    PA452
    Western PA
    I have an '07. I was thinking of the mechanical LSD, not the new electronic "Auto LSD". Can't turn mine off. :cool:
  15. Jan 6, 2010 at 4:00 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    good to no.i dont have that option.i have the locker and hardly ever needed it.now have i used it?YES and man does it work.
  16. Jan 6, 2010 at 4:14 PM
    kilgoja
    Alabama
    :mudding:
    oh..lol..sorry bout that...i totally overlooked that you had an '07...i have no idea what my old '88 had....maybe mechanical like urs or maybe nothing...lol....i'm no expert at the lsd or locker stuff....i guess lockers are useful for off roading out west with all the big rocks and stuff...i really never understood why you couldn't just use the grip from the front tires while in 4wd to get you out of a jam if you had a rear tire up in the air...but some people get several tires up in the air when they off road...lol..i never really did anything that serious as far as off roading goes...around here it's mostly mud and small rocks
  17. Jan 6, 2010 at 4:16 PM
    PA452
    Western PA
    Yeah, I sometimes forget that the new ones no longer have the mechanical LSD. :)
  18. Jan 6, 2010 at 4:25 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Both models have limited slip. The OR adds a locker and ATRAC. So if you get the OR, you still have LSD.
    IMO - the locker is of less value than ATRAC.
  19. Jan 6, 2010 at 6:33 PM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    With a good set of tires,all this worry goes out the window.If you push any truck in the wrong conditions it will fishtail.Therefore dont drive like a teenager and you will be good 90% of the time.I have an 07 with the locker mod and really have to push it in the rain to lose traction with it off.More often than not with it unlocked in dirt I still leave a posi mark.As for the new trucks with all these extra buttons and such, and all these guys trying to figure out how to use them and what conditions call for each, I am glad mine has 1 fucking button!Control is left to the driver, not depending on all sorts of gadgets to keep me straight,or in my lane,or in some cases like the prius park the damn thing.I had a detroit locker in my 91, now that was some unpredictable winter driving!
  20. Jan 6, 2010 at 6:40 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    This is the case with all rear wheel drives, including cars. Front wheel drive produces understeer and rear wheel drive gives you oversteer.
