Locker while in high 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by allenn, Feb 18, 2022.
  1. Feb 18, 2022 at 4:15 PM
    allenn
    allenn [OP] Well-Known Member
    2020 TRD Pro
    Does any of the programmers/tuners allow you to be able to engage the locker in high 4wd instead of just low? I know with my last Jeep that was a option.
  2. Feb 18, 2022 at 4:24 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Why would you want that? In what situation would you find it necessary?
    Having the locker in 2wd could be fun for snownuts, but still not necessary for 90% off road needs.
  3. Feb 18, 2022 at 4:26 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Not to my knowledge OP
    I’d like it too and I’m tuned, never something I’ve been asked or read about.
    4wd has a separate ECU, so something like the 2lo harness for the locker may work. WAY over my pay grade but if someone makes it I’d gladly plug it in!
    allenn[OP] likes this.
  4. Feb 18, 2022 at 4:27 PM
    allenn
    2020 TRD Pro
    I want it for high 4wd. 95% of time my truck gets used in high 4wd. You may be crushing 35mph down a dirt road then get to really bad mud where a locker is nice. Keeps you from going from 4high to 4 low
    Wulf likes this.
  5. Feb 18, 2022 at 4:30 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Wait, guess I’d also need the locker!
    But, you get the idea! :cheers:
  6. Feb 18, 2022 at 4:31 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Also lots of fun in the snow!
    allenn[QUOTED][OP] likes this.
  7. Feb 18, 2022 at 4:33 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    I see your thought process, but have you considered the lack of high HP/torque these Tacos have? You'd be chucking it down to 4Lo anyways to again kind of torque once you start to get bogged.
    If it's not so sticky that it doesn't bog you, you will probably do just fine open diff.
  8. Feb 18, 2022 at 4:33 PM
    allenn
    2020 TRD Pro
    They dang near shut everything down here in Louisiana with even a chance of snow. I bet it would be fun though!
    Natetroknot[QUOTED] likes this.
  9. Feb 18, 2022 at 4:35 PM
    allenn
    2020 TRD Pro
    You’re right it may not make any difference at all in high. I was just curious if this was a option. Lots of holes here one side may be rutted up way worse than the other making it have way less weight on one side.
  10. Feb 18, 2022 at 4:37 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You could always swap out the E-Locker for an ARB air locker. Bypass all the Toyota electronics.
    Tocamo and allenn[QUOTED][OP] like this.
  11. Feb 18, 2022 at 4:41 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Wire the 4Lo transmission switch to ON. Youll have locker in 2wd, 4Lo and 4Hi.
  12. Feb 18, 2022 at 4:43 PM
    allenn
    2020 TRD Pro
    I’m to scared to be moving wires lol
  13. Feb 18, 2022 at 4:47 PM
    Black DOG Lila
    Virginia
    Fear is the mind killer
    No 2wd or 4Hi locker for you
  14. Feb 18, 2022 at 4:47 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You go first! :boink:
  15. Feb 18, 2022 at 4:55 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I'm curious what jeep you had that allowed rear locker in 4hi? My 2019 Rubicon won't allow me to do that. I think a Taser might have that feature but that's an aftermarket item.
  16. Feb 18, 2022 at 5:05 PM
    allenn
    2020 TRD Pro
    18 rubicon jl I had the super chip trail dash I think. I was running a 44” tire and it said would calibrate speed odometer up to 44”tire
    which was a lie/misprint I guess. I’m almost certain that being able to run a locker in 4high was a option with one of the programmers unless I’m loosing my mind.
    Matic[QUOTED] likes this.
  17. Feb 18, 2022 at 5:06 PM
    Username1000
    Username1000 Well-Known Member
    Jon
    2021 DCSB OR 6MT MGM
    My work truck is a '14 F150 and I'm pretty sure you can lock the rear in 2wd, 4High, and 4Low. I've locked the diff and I don't think I've ever needed 4low
  18. Feb 18, 2022 at 5:10 PM
    allenn
    2020 TRD Pro
    Tocamo and Matic like this.
  19. Feb 18, 2022 at 5:10 PM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    Look up @BigWhiteTRD ’s rear locker anytime mod. One of the best things I’ve done to my truck!
    BigWhiteTRD and allenn[OP] like this.
  20. Feb 18, 2022 at 5:11 PM
    allenn
    2020 TRD Pro
    Awesome thanks!
    BigWhiteTRD likes this.
