Locker Won't Disengage After Re-Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ubaderb, Apr 22, 2021.
  1. Apr 22, 2021 at 8:42 PM
    Ubaderb
    Ubaderb [OP] Well-Known Member
    15 Tacoma TRD OR
    It always seems to be something with my work. Went for a test drive after my re-gear and instantly noticed my locker was engaged while I was backing out of the driveway. I drove across the street in the parking lot and tried everything to get it to disengage, no luck. During the removal of the rear I know you have to move the little gear towards the left. When I went to reinstall I had to move the gear back to the right to get everything to fit. Before I called it quits for the night, I removed the motor to see if anything was loose. Everything looked fine. I could not get the gear to move this time. I don't know if that is by design or not. I would appreciate any help!
  2. Apr 23, 2021 at 11:40 AM
    Ubaderb
    15 Tacoma TRD OR
    Anyone? Kind of in a pinch as this is my only vehicle. If it comes down to it I don’t mind to pull everything and start over. Just want to make sure I do everything right!
  3. Feb 17, 2024 at 7:34 PM
    imaiami
    imaiami Active Member
    Dustin
    AZ
    2019 Cement TRD OR 6MT Taco Ol Girl
    Suspension FR-ADS 2.5 coilovers w/ remote comp adj resi, MCM upper arms RR-ADS Tripple bypass shocks, air bumps, U-bolt flip kit, Deaver U-402 leafs Custom Sliders Coastal Offroad skiddies BFG 33's Black Rhino Realm 16s X Trek Grill TRD Pro Headlamps
    Old thread, but what ended up being the fix? I just regeared and I’m locked nonstop. I even unplugged the plug to the diff, and no change. ‍♀️
  4. Feb 17, 2024 at 7:36 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    OP hasnt been active since September, try posting a thread in the morning when more members are online
  5. Feb 18, 2024 at 8:41 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  6. Feb 18, 2024 at 8:51 AM
    imaiami
    Dustin
    AZ
    Thanks,
    in my haste last night after my first drive after regearing, This was the only thread I could find albeit a 2nd gen thread.
    unfortunately the third gen diff is actuatorless andddd im an idiot posting in a 2nd gen thread.
