Locker Won't Engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elvota, Mar 19, 2019.
  1. Mar 20, 2019 at 7:15 PM
    Elvota
    Elvota [OP] Well-Known Member
    2006 Tacoma TRD
    I agree.... and repaired that one as well. I may try and source a new plug eventually.
    Anyone happen to have a part number for the plug?
  2. Mar 20, 2019 at 9:56 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    So happy for you!
  3. Mar 21, 2019 at 8:48 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Glad to hear you got it sorted.
    I remember cutting those wires on the 4wd ecu back when my truck was a year old and had 10,000 miles. :goingcrazy: :sawzall:
    b_r_o likes this.
  4. Mar 21, 2019 at 11:35 AM
    Muddinfun
    Muddinfun Well-Known Member
    @DaveInDenver is the connector expert. He'll be able to help you out with connector and pigtail part numbers.
    Also, looking at the schematic, there are 2 limit switches and 1 of the 2 wires is always grounded. So, when the ECU didn't see a ground on either wire, it said, "Nope, not gonna do it."
    RCBS and b_r_o like this.
  5. Mar 21, 2019 at 12:16 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Harness side connector (plastic housing part) is 90980-11194. The repair pigtails are 82998-12440.
    But this is a cheaper option that should be interchangeable from the OEM for Toyota connectors:
    https://www.corsa-technic.com/item.php?item_id=963
    BTW, if you get the generic replacement make sure to get one cavity plug, there's only 5 wires in the locker harness so you have to blank one.
    b_r_o and Muddinfun like this.
  6. Mar 22, 2019 at 5:50 PM
    Elvota
    2006 Tacoma TRD
    b_r_o likes this.
  7. Feb 17, 2022 at 9:47 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    Hello I am resurrecting a dead thread!
    This worked for me first try! Was getting frustrated because everything had voltage etc. and then this simple fix made everything okay.
    I drove up and down some dirt roads once I had it engaged and now when I try to engage the locker it is almost instant and I don't have to do this trick anymore.
    TnShooter and David K[QUOTED] like this.
  8. Feb 17, 2022 at 12:25 PM
    David K
    Sweet!
