Locker?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dole, Jul 17, 2010.
  1. Jul 17, 2010 at 5:30 PM
    Dole
    Dole [OP] awesome
    4x4
    wicked flow
    I have a 99 4x4 v6 that currently doesnt have a rear locker. what are some good lockers available?
  2. Jul 17, 2010 at 5:32 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    ARB, Detroit, Trutrac, Auburn
  3. Jul 17, 2010 at 5:34 PM
    Dole
    Dole [OP] awesome
    4x4
    wicked flow
    thanks for the response. where do you recommend buying one? and which one is the cheapest?
  4. Jul 17, 2010 at 5:38 PM
    RPain
    Chandler, Arizona
    not too sure i haven't bought any lockers but do your research on each one of them and pick the one that fits your needs for the money
  5. Jul 17, 2010 at 5:39 PM
    Dole
    Dole [OP] awesome
    4x4
    wicked flow
    will do. thanks man
  6. Jul 17, 2010 at 5:44 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    arb is the best because its a selectable air locker which you can activiate and turn off when not needed. it will save your tires and give you better every day drivability as you will not know its there
  7. Jul 17, 2010 at 5:45 PM
    Dole
    Dole [OP] awesome
    4x4
    wicked flow
    So will this help me get out of those sticky situations?? And which one would i get? soo many options
  8. Jul 18, 2010 at 7:42 PM
    98fourbangertaco
    98fourbangertaco Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    I have the detroit truetrac in the rear because i drive my truck on the road daily, its a limited slip but its a gear type instead of the conventional clutch type so u dont have clutches to slip or wear out so that means that both wheels will pull no matter how cocked up the suspension is and i cant even tell thats its there on the road till you spin the truck, pretty much the mericale locker if you are goining to be driving your truck on the road in my opinion, ive been in situations where one wheel is completely off the ground and it just pulls right on through, im planning on ordering one for the front too within the next few weeks
  9. Jul 18, 2010 at 10:36 PM
    Dole
    Dole [OP] awesome
    4x4
    wicked flow
    ok thanks. how hard was the install? do i need a press?
  10. Jul 19, 2010 at 5:34 PM
    jcmartinez17
    jcmartinez17 Well-Known Member
    jc
    ontario
    10 trd tacoma prerunner
    can i put a locker in my 2.7?
  11. Jul 19, 2010 at 5:38 PM
    98fourbangertaco
    Taylorsville, NC
    Yea u will either need a press or let someone that has a press do it for u, u will also need new carrier bearings if you go with a locker that replaces the whole carrier (which is all of them except the lockright) unless you have a special machine to remove them with out messin em up, and yes you can put a locker in a 2.7, thats what my truck is and i put the truetrac in the rear and am planning to do the same to the front sometime soon
  12. Jul 19, 2010 at 5:42 PM
    HusqyRider
    HusqyRider Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    @dole: You should have it professionally installed if you are not a near-expert with a wrench and have done gear work before. the work is intricate and painstaking.
    @jc: engine size doesn't really matter, but what axle you have does.
  13. Jul 19, 2010 at 7:06 PM
    98fourbangertaco
    Taylorsville, NC
    Me and my dad done the install on mine and it wasnt all that bad, but like HusqyRider said what matters is what axle u have, it doesnt have anything to do with the motor unless what motor u have determines what axle you have
  14. Jul 19, 2010 at 7:32 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Toyota E-locker is the best!
  15. Jul 20, 2010 at 5:26 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Powertrax no-slip easy to install, DIY and pretty cheap $410 - 465
    Does not ratchet like the lockrite
  16. Jul 20, 2010 at 12:22 PM
    jcmartinez17
    jc
    ontario
    how can i tell what kind of axle i have, i know that i have 4.58 gears.
    oh and my 2.7l is automatic too
  17. Jul 20, 2010 at 12:27 PM
    BRP27
    04 4X4 Tacoma SR5
    Not sure what you are asking, but if you don't have the TRD offroad option which is an e-locker and you have not modified the rear diff, the rear end is an Open Differential.
  18. Jul 21, 2010 at 3:38 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Are you sure? Unless someone messed with it, I don't think any version of the Tacoma came with factory 4.58s...
    Look in your door sill on the driver side. Theres the little sticker with the vin and tire pressures and such. There's a 4 digit code somewhere on there that's a letter, 2 numbers, and a letter. Mine reads "A02A". This is the axle code for your truck. I'm sure someone will post it, but theres a table somewhere on here that tells you what each code means.
    Good Luck
  19. Jul 21, 2010 at 9:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Check out this thread gear ratio codes
  20. Jul 22, 2010 at 4:53 AM
    BRP27
    04 4X4 Tacoma SR5
    Gear Codes
    From Faq
    [edit]
    THIS CHART IS FOR '95.5-04 MODELS ONLY!
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
    Edit by Ed Quinones on 10-7-05: I used to own a 99 Prerunner ext cab 2.7L with auto tranny and gear code of B07A. It came from the factory with a 4.56 gear ratio.
