Lockers and posi for 2wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by bgdeer1, Mar 15, 2010.
  1. Mar 15, 2010 at 6:50 AM
    bgdeer1
    bgdeer1 [OP] Well-Known Member
    minooka il
    tacoma prerunner
    3 inch lift in back 1 1/2 front. 31' mesa A/T's. Alpine deck, alpine speakers, l5 kicker solo baric sub
    How can i change my 1 tire fire into a 2wd or "posi" as they call it.. Would a locker fix that and how much do they run? and how does it all work any answers???
  2. Mar 15, 2010 at 7:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yeah...
    I highly recommend you visis www.google.com and do some research.
    Tons of different lockers available, different price ranges, for different purposes. Depends on what you want it for......pros & cons for all varieties of lockers.
  3. Mar 15, 2010 at 10:31 AM
    bgdeer1
    minooka il
    tacoma prerunner
    can any one help me with the basics of a locker? pros and or cons.. i understand the concept but i need advice more than info.. i dont want just 1 tire fire i want both ya know? mild mud, snow etc.
  4. Mar 15, 2010 at 10:34 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if your a xcore trail runner then go with a locker, if you do 80-90% of driving ON road then go with a LSD or "posi" rear end.
  5. Mar 15, 2010 at 10:40 AM
    bgdeer1
    minooka il
    tacoma prerunner
    ok i drive mostly road.. but for weekend fun? i want that 2 tire power ya know? i want something not toooO! expensive if you know what i mean.. what should i do??? i want to be able to stay with the 4x4 and play and have fun at the same time not spend to much.. maybe be able to do it myself and put it together. anyone have anysites i can see and anyone have any rough prices??
  6. Mar 15, 2010 at 10:54 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    There are lockers that are always activated. They work miracles off road but can be a little feisty on road, especially in wet or icy conditions. These range from a couple hundred bucks for a lunchbox locker on up to nearly a thousand.
    A selectable locker is probably what you want, ARB is one example. It drives as a normal open diff creating the on road manners you've come to expect. When you hit the nasty stuff, you push a button and the rear axle locks moving both tires as one giving you massively improved traction. These are $800 for parts and a few hundred more for labor.
    If you can find a TRD Off Road donor truck of your generation. You can pull the selectable locker rear axle off of it an bolt it straight on to yours. I'm sure if your patient you could find an axle for less than $1000 no problem. I don't really know the price range though.
    A posi or limited slip is another option. They split the difference between an open axle and a locker. They behave well on the road and "limit" slip off road. They are in the price range of the less expensive lockers.
  7. Mar 15, 2010 at 11:05 AM
    bgdeer1
    minooka il
    tacoma prerunner
    ok so what would be the cheapest route for me that will give me the extra Umph im looking for offroad wise?
  8. Mar 15, 2010 at 11:10 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    "Lunchbox" lockers like Lock Rite or Powertrax can be found in the 2 to 3 hundred dollar range. If you're handy, you can realistically install one of these yourself, too.
  9. Mar 15, 2010 at 11:13 AM
    bgdeer1
    minooka il
    tacoma prerunner
    yeah im looking at the powertrax locker that is for my truck prerunner 03. 310$ Do i need anything else or is it install and bam its all good. Is this the cheapest route and will give me extra traction and power for off roading? Is the wiring needed to engauge and disenguage these lockers or how does it work?
  10. Mar 15, 2010 at 11:16 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I'm a little new to this too. What is the difference between a lunchbox locker and the more expensive models? What is the difference between, stock and posi. and posi and locker? what is posi short for? Is it like a system that detects when the wheel with power is not the wheel with traction and sends power to the opposite wheel accordingly or something?
  11. Mar 15, 2010 at 11:20 AM
    bgdeer1
    minooka il
    tacoma prerunner
    can some one post me a link for a powertrax locker 4x2 4cyl tacoma. or anyother lockers that will be good ??
  12. Mar 15, 2010 at 11:25 AM
    bgdeer1
    minooka il
    tacoma prerunner
    would a locker for a tacoma 4x2 V6 work for a v4???
  13. Mar 15, 2010 at 11:33 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Aside from new diff fluid, install and bam it's all good. A "Lincoln locker" is cheaper, free in fact, but you don't want that. That is for off road only. There are no wires or anything. It is an automatic locker that is always engaged. Imagine with traction, that when the drive shaft turns, the tires turn respectively to the speed of the shaft. A powertrax will allow one wheel to turn faster (the outside wheel on a curve) than the drive shaft is pushing. However, it won't allow a wheel to turn slower than than the drive shaft is pushing (one tire spinning in mud and the one sitting there picking its nose).
    Lunchbox only replaces certain parts that the decent shadetree mechanic can handle. More advanced lockers require more parts to be replaced. These parts need very specific tolerances and whatnot that the average joe probably shouldn't be messing with.
    Posi-traction is a proprietary name (I think). It is actually a limited slip system. It's like generically calling soda "Coke", or inline skates "Rollerblades".
    Search the Internet. There are cool videos and everything out there to help explain some of this.
  14. Mar 15, 2010 at 11:48 AM
    x2468
    limited slip is essentially what comes stock though correct? It allows one wheel to spin faster than the other for turns and such?
    why would anyone get the more expensive locker if they can just get the lunchbox one??? I guess that is what I was asking in my original question, although why one is more expensive than the other would have been my next question anyway.
  15. Mar 15, 2010 at 11:49 AM
    bgdeer1
    minooka il
    tacoma prerunner
    so powertrax is a good brand locker and will get me what im looking for? It will give me the TRUE 2wd power? Now for the negitives, will i loose any power, loose MPG's? or what not. Im really wanting a locker to get me through some of the stuff i get stuck on. im sick of getting one tire off the ground and that happens to be the one thats spinning.. (sigh).. So Powertrax locker is the way for me? cheapest but good quality, easy to install?
  16. Mar 15, 2010 at 11:50 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Do you have 5 lug nuts per tire or 6? There is some variation within Toyota axles.
  17. Mar 15, 2010 at 11:51 AM
    bgdeer1
    minooka il
    tacoma prerunner
    i have a 5 lug i think 03 prerun
  18. Mar 15, 2010 at 11:52 AM
    bgdeer1
    minooka il
    tacoma prerunner
    6 lugs sorry!
  19. Mar 15, 2010 at 11:54 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    More expensive type is typically stronger. Unless you're beating the hell out of it, you won't break either one. More expensive ones can also be selectable meaning you can turn them on and off with the flip of a switch.
  20. Mar 15, 2010 at 11:55 AM
    bgdeer1
    minooka il
    tacoma prerunner
