Lockers front and rear
Discussion in 'Technical Chat' started by jlwarren1015, Jun 2, 2014.
  1. Jun 2, 2014 at 6:21 PM
    jlwarren1015
    jlwarren1015 [OP] Member
    Jeff
    Arlington, Texas
    2012 Tacoma TRD SPORT
    IM still really new here. Im looking to put lockers on 2012 TRD sport 4x4, But cant spend the money for ARB, can I get some recommendations for the front and rear, something like an aussie in the rear but its straight axels whats the deal on the front.. Any help would be great!!!!
  2. Jun 2, 2014 at 6:40 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Lockers come in 4 basic varieties:
    1. Limited slip
    2. Automatic
    3. Selectable
    4. Spool
    The locker you choose depends upon your need and terrain. A spool directly attaches the ring gear to your axles. This transmits 100% of the power equally to the wheels with no bias. Works great in limited applications but makes it undrivable on the street.
    An automatic locker provides power equally to both wheels under load but are suppose to "open" when the load is released. Different makes are more/less sensitive but basically work the same. In the rear axle, they can be streetable with practice but not advised if you experience snow and ice conditions. The front axle is unadvisable if driving on the street due to understeer. You'll also get uneven tire wear.
    Limited slip is the best locker in terms of road manners (besides an open carrier) as they do allow biasing between wheels when cornering. This road manner benefit, however, means you will not get the same performance offroad as you would other lockers.
    A selectable is the best of both worlds. Open carrier on road and a spool offroad.
    If this is a DD or spends alot of time on pavement, a selectable or limited slip will probably be your best option. With limited slip, I prefer the Detroit Tru Trac since it does not use friction discs which can wear out nor does it require friction modifiers. You'll get varied opinions but I've never had issues with understeer running a Tru Trac in the front.
  3. Jun 3, 2014 at 4:54 PM
    jlwarren1015
    Jeff
    Arlington, Texas
    Awesome thanks a lot. This is great info. I guess I need to kinda shop around and see what I can find
  4. Jun 3, 2014 at 5:03 PM
    jlwarren1015
    Jeff
    Arlington, Texas
    BTW Im from Arlington TX as well!!
