lockers or winch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SRV06, Mar 17, 2011.
  1. Mar 17, 2011 at 8:22 AM
    SRV06
    SRV06 [OP] The man with(out) a plan
    dMa
    Texas
    06 SR5 4x4
    Plenty of mods to come.
    Alright. So I have a 4x4 Sr5 and I do small time trail riding and stuff but am debating on weather lockers would do me better or a winch for those few times I get stuck:mad:. And I should specify this my daily driver so a luchbox locker is not really an option for me, was looking at arb. Just want to see what yall think is money better spent. Thanks!
  2. Mar 17, 2011 at 8:24 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i say locker..............with a winch......you gotta have a place to mount it. and arb makes some awesome air lockers.
  3. Mar 17, 2011 at 8:24 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    well they are both good, a winch will always get you out if theres something near by, a locker wont, but like tacoman said you need a place to mount it. i would go with a locker cause i rarely get stuck anyways.. but up to you!
  4. Mar 17, 2011 at 8:25 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    It really depends on how bad you get stuck and what type of terrain you will be mostly on.
    One reason I went with a winch for now, is because it is cheaper and it can get you unstuck in certain cases where lockers would not.
    Lockers are nice because it's a lot easier to get unstuck instead of needing to pull out the winch line and do all that.
  5. Mar 17, 2011 at 8:32 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    would the locker have helped you the few times u were stuck?
  6. Mar 17, 2011 at 8:36 AM
    especk
    Erik
    Redding, CA
    I've been stuck in rocks and the lockers would definitely have helped most times.
    I've been stuck in very slick shallow mud trying to go uphill and the lockers would not have helped. (I know this because it happened with my 06 TRD OR with rear locker.) I definitely needed a winch. It almost caused me to slide sideways off the trail and down a steep ravine :eek:. I had to get winched out by another vehicle.
  7. Mar 17, 2011 at 8:37 AM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    I would say winch..... you can get yourself out and others out....
  8. Mar 17, 2011 at 8:42 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    well, what are you going to do when you get stuck after you install the locker?
  9. Mar 17, 2011 at 8:49 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I have done a lot of four wheeling... in my 3 Tacomas (all with a rear locker), I have NEVER needed to be winched... The locker adds the traction or lowering air pressure in the tires increases the traction.
    Lockers (as in front and back) would be even more reason not to get stuck.
    I would rather spend money to keep from getting stuck than to buy something because I know I will get stuck.
    Next time, get the Off Road TRD 4WD! Stuck? Doesn't know the word!
  10. Mar 17, 2011 at 8:54 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    IMHO this is the best advice you can get. Look at your situations and what is most needed and what your money will allow. But keep this statement in mind.
  11. Mar 17, 2011 at 8:57 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I went for the Winch first. You can get stuck no matter how many traction devices you have. A winch can always pull you through to the other side.
  12. Mar 17, 2011 at 9:02 AM
    David K
    I have always gotten myself out of any situation... Where I go four wheeling there are neither people to help nor trees to winch onto usually.
    Includes the couple of bad stucks I got into, before my Tacomas.
    You just have to figure a way out... Lowering the tire pressure is often the solution. Sand, snow, riverbottom... I was stuck in a rising flash flood arroyo in Baja once, in my Subaru 4WD wagon (1978)... Tires were under water, but before it poured into doorways, I thought of lowering the air pressure... and it worked!
    Once when I was sunk in yuk mud on a tidal salt/ mud flat (accidentally got off the firm track across it to the beach, at night. Slept in vehicle and next morning I walked and found some wood. Jacked up my vehicle and placed the wood under the tires... That stuck was the longest... and there are no trees on a mud flat next to an ocean lagoon to attach a winch cable to.
  13. Mar 17, 2011 at 9:08 AM
    especk
    Erik
    Redding, CA
  14. Mar 17, 2011 at 9:08 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    :SingingSong,BreakOnThroughToTheOtherSide: with a winch.
  15. Mar 17, 2011 at 9:09 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    See Lrgrnr, you just not cool enough :p
  16. Mar 17, 2011 at 9:16 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    The only problem with lockers is when you get stuck you're really stuck. I'd get gear that gets you out of situatations before you get gear that gets you into situations.
  17. Mar 17, 2011 at 9:18 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    This^^
    I have always wheeled on the premise of, only in 4WD if I'm not moving in 2WD.
  18. Mar 17, 2011 at 9:27 AM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    I don't have any personal experience/advice on this but like others have said maybe try to get both? If not maybe locker first then winch soon after? I say locker first only because you don't have a traction device already so see where just a locker can get you.
  19. Mar 17, 2011 at 9:30 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I did the winch first, Larry summed it up pretty well i think.
  20. Mar 17, 2011 at 9:37 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    I hunt alone.... i have to go offroading to get there.... am i stupid?
