Lockers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kirk1589, May 28, 2013.
  1. May 28, 2013 at 9:17 AM
    Kirk1589
    Kirk1589 [OP] Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I have an 03 SR5 I'm building as a DD and weekend wheeler. Looking for a good locker that is RELIABLE and easy going on the street. Looking for both front and rear.
    Set up
    235/85 Kevlars
    Allpro non expo 3'' leafs
    Eibach coils
    5100's front set at zero
    Rear 5100 series
  2. May 28, 2013 at 10:06 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Arb air lockers front and rear?
  3. May 28, 2013 at 1:36 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I'm in college lol. ARB is what I am looking at for the rear
  4. May 29, 2013 at 9:33 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    With anything else you get what you pay for. My advice is waiting until you can afford something quality that you won't want to immediately replace post graduation with your fatter wallet. Just to clarify by no means am I saying that ARB is not a quality product. My advice has to do with cheaper options for the front. I think this applies to a lot of purchases in life. Until then stick with lockers that you put your textbooks in. haha
  5. May 29, 2013 at 9:38 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you smell that? It's the sound of ARB lockers in the morning...
    The sound they make when they disengage is enough to make everyone green with envy!
    I had a pair of ARB's in my Jeep. Best damn thing since sliced pizza & beer! :D
  6. May 29, 2013 at 10:44 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Well to make it more clear. I know ARB will be in the rear. What about the front? I can tackle the rear myself at work but don't dare touch the front. Im looking for longevity and reliable as the manufacture of the truck.
  7. May 29, 2013 at 10:55 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    do you have manual hubs? if so you can go with a lunchbox locker up front.
  8. May 29, 2013 at 11:03 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Arb's are gonna be the most reliable. If I were you id spend the money and get an Arb for the front, its certainly not your only option for the front but certainly the most widely used. Then source a stock e locker for the rear, would be more than adequate for weekend wheeling. And let's not forget the cool factor of having on board air.
  9. May 30, 2013 at 5:59 AM
    Janster
    Jandy
    Lancaster, PA
    ARB for the front also....
    Are you familiar with setting up ring & pinion gear setups? If you are not fully and professionally familiar with setting up ring/pinion gears in an axle, then you should take your truck to the professionals to have the ARB installed.
    I'm not arguing the fact that you (or anyone else) can't install an ARB. If its not done properly, you could experience a lot of different issues which ultimately could destroy your ARB investment. And....in today's market, it looks like you can pay upwards of $900 for an ARB. Yikes!!
    Just sayin....
  10. May 30, 2013 at 6:04 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I would put a lunchbox in the rear to save money and put the arb up front.
  11. May 30, 2013 at 7:44 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    ASE Tech. I am doing a lot of research on what I want and need.
  12. May 30, 2013 at 7:45 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pinching coins now will turn into spending coin later.
  13. May 30, 2013 at 7:48 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Get the ARB's front and rear, or don't do it. Don't make the same mistake I did. I ended up buying ARB's for the front and rear after buying auto lockers. You'll end up kicking yourself if you don't do it right the first time.
  14. May 30, 2013 at 8:02 AM
    Southern01Taco
    Sean
    Holden, La
    I agree, but there is nothing wrong with a lunchbox locker. If my truck didn't have the e-locker and had manual hubs in the front, I would run lunchbox's front and rear.
  15. May 30, 2013 at 8:16 AM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    I'm not sure why people are so against lunchboxes, I would have no issue using them. And tons of jeep guys run Aussies and lock rights with zero issue. It's just a cheaper option.
  16. May 30, 2013 at 8:46 AM
    Davtopgun
    David
    Central Alabama
    Auto lockers are fine in the rear, once you learn how to drive on road with them. It's a bad idea in the front of a taco, even with manual hubs. You'll be snapping CV's like twigs. IFS isn't made for the kind of stress that a auto locker would put on it.
  17. May 30, 2013 at 8:50 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I had one in my ford and the clicking and noise that thing made when I was turning to allow one wheel to spun freely was annoying.
  18. May 30, 2013 at 8:52 AM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    That is very true. Would make for constant costly repairs. I didn't even think about it. I know a few guys running lockrights out back and they say once you "learn" how to theres no issue.
  19. May 30, 2013 at 9:27 AM
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
    What about eaton lockers?
  20. May 30, 2013 at 11:08 AM
    BamaToy1997
    Bill
    Navarre, FL
    This right here ^^^ There is no substitute for doing things right. OP, as you are an ASE certified tech you should understand that for sure. ANYTHING other than a selectable locker in the front is asking for potential trouble. When you are wheeling and the front steering is turned, even a small amount, the front wheels will want to move at slightly different speeds. The tighter you have the steering turned, the more the difference. Having a selectable locker allows you to disengage the locker, releasing that "bind" and then reengaging the locker to regain the traction. It does take a bit of driver skill to work an ARB, as my friend Dave can attest to. You can EASILY break a CV axle or worse. Now granted, a lot of people are running standard lockers in the front and not breaking things. But others ARE breaking things, and when something breaks, it costs money. If you want a low cost alternative to the ARB then you can look at Yukon's Zip Locker that is pretty much the same thing as an ARB, and they are made here in the US. You came asking for thoughts, and these are them: ARB or other selectable in the front, Yukon Gear Grizzly locker in the rear. Those are my suggestions.
    A properly installed and lubricated locker should not ratchet that loud. I have ran rear lockers in many different trucks and when they started to click I would change the fluid and noise would be gone. Lockers require more maintenance than open or LSD differentials.
