Lockers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luke3478, Nov 13, 2019.
  1. Nov 13, 2019 at 8:21 PM
    Luke3478
    Luke3478 [OP] Member
    Luke
    06 Tacoma sr5
    4 inch lift, 31s, motto metal rims, bed cover, Westin front bumper, two front light bars, and two rears light pids
    I have a 06 that’s an sr5, i know they say that it’s a open diff but i have the outside tire wear like lock-rite. Is that what i really have or?
  2. Nov 13, 2019 at 8:22 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Or... Bad alignment?
    Yes, you have an open diff. You buy the truck used?
  3. Nov 13, 2019 at 8:26 PM
    Luke3478
    Luke
    06 Tacoma sr5
    I’ve had it aligned twice and the wear is mainly in back. And yes i bought used.
  4. Nov 13, 2019 at 8:27 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Sounds like your thrust angle is off.
  5. Nov 13, 2019 at 8:28 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I misread your post. Tires under inflated?
    whatstcp and ryfox0276 like this.
  6. Nov 13, 2019 at 8:31 PM
    Luke3478
    Luke
    06 Tacoma sr5
    When it’s in four the back doesn’t seem to spin, I’ve never looked while in mud but when in gravel there’s no slip
  7. Nov 13, 2019 at 8:34 PM
    ryfox0276
    Montana
    2013 RC 4x4
    But if you make a u turn on pavement, does it lock up?
    LAMCKMA007 and whatstcp like this.
  8. Nov 13, 2019 at 8:37 PM
    Luke3478
    Luke
    06 Tacoma sr5
    Yes, on pavement it does try to quit and lock up
  9. Nov 13, 2019 at 8:38 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Can you contact the previous owner?
  10. Nov 13, 2019 at 8:42 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    Spray water on the ground in front of the rear tires, floor the gas pedal, get out of the truck and see which tires spun.
    Rexfordian13 and ryfox0276 like this.
  11. Nov 13, 2019 at 8:43 PM
    ryfox0276
    Montana
    2013 RC 4x4
    That's a better idea than the redneck idea I had in mind to test this...
  12. Nov 13, 2019 at 8:44 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Yup.
    whatstcp[QUOTED] likes this.
  13. Nov 13, 2019 at 8:45 PM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    Idk I'm a redneck lol
    ryfox0276[QUOTED] likes this.
  14. Nov 13, 2019 at 8:46 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Great minds think alike :anonymous:
    LAMCKMA007[QUOTED] likes this.
  15. Nov 13, 2019 at 8:48 PM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    That would determine a locker is present but not necessarily a limited slip being present.
    ryfox0276 likes this.
  16. Nov 13, 2019 at 8:52 PM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    Water on the ground in front of tires, floor the go pedal, get out and look at the tire marks, 1 tire spun it's an open diff, 2 tires spun starting and stopping reality close to the same spot it has a locker, anything in between and it has a limited slip of some sort.
  17. Nov 14, 2019 at 6:58 AM
    Luke3478
    Luke
    06 Tacoma sr5
    I can contact a previous owner, and in 2wd sometimes and sometimes not it will try to lock up on pavement
