Locking axe with quickfist moubt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasclair, Jun 29, 2014.
  1. Jun 29, 2014 at 4:44 PM
    jasclair
    jasclair [OP] Well-Known Member
    joshua
    Bend oregon
    Current: BHLM, plasti dip badges/bumper, Satoshi homer taco style grille, custom TRD, pack rack Marshall fab, window tint,interior paint job, ome lift,wheels spacer, white light interior, retrofit headlights.
    Anybody have any ideas on a way to lock up an Axe using the quickfist mount? Only idea so far is to zip tie it but that still is t a great anti theft protection idea.
  2. Jun 29, 2014 at 4:47 PM
    jasclair
    joshua
    Bend oregon
  3. Jun 29, 2014 at 4:47 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    an axle? like an axle housing, axle shaft or a cv axle?
    I will assume you are talking about a cv axle. Instead of having it strapped inside the bed...invest in a large heavy duty tote or pelican case for all of your tools and spare parts when off roading. that way when its time to go you throw the whole case/tote in the bed and you are all packed in that department.
  4. Jun 29, 2014 at 4:54 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
  5. Jun 29, 2014 at 4:57 PM
    jasclair
    joshua
    Bend oregon
    Nvm just saw this and I think it will be awesome to use. Just slide through the axe handle into one of the many rail holes... So if anyone else needs help I'm gonna buy this and update this thread once I get it.
  6. Jun 29, 2014 at 6:55 PM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    How about one of those small cable locks you get like when you buy a shot gun? You could go through the hole in the end of the handle.
  7. Jun 29, 2014 at 7:09 PM
    jasclair
    joshua
    Bend oregon
    dude i saw one at walmart online!! gonna see if they have it at the store. if so i will try that tonight!! I was thinking the same thing man!!!
  8. Jun 29, 2014 at 7:16 PM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    Check your local hunting/fishing store. A lot of times you'll find them giving those things away for free to promote gun safety.
  9. Jun 29, 2014 at 7:22 PM
    jasclair
    joshua
    Bend oregon
    will do man!! thanks didnt know they do that.
  10. Jun 30, 2014 at 7:41 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    If you do that, you'll want to keep that thing soaked with a lube/rust preventer or something, I doubt those locks are designed to be left out in the elements. When you need that axe, you're not going to have time to mess around with a jammed lock.
  11. Jun 30, 2014 at 7:47 AM
    jasclair
    joshua
    Bend oregon
    got the gun lock and its perfect, recommend it for quickfist locking if anyone needs that. Thanks for the tip ssanders2211. I will keep that in mind
  12. Jun 30, 2014 at 8:47 AM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    This is a very good point. Might wrap a balloon or condom around it! Lol:eek:
