Locking Diff Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtacoma1, Mar 9, 2011.
  1. May 11, 2011 at 5:20 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Thank you for that!
    It is just fun to have so many options... but in reality, driving the truck is easy on and off road!
    The standard mode (TRAC) in H4 is what you use and when you go into Low Range, press the A-TRAC button once, and leave it that way. Every time you go into L4, the A-TRAC will be on stand-by for whenever you lose traction on any tire... then, and only then with it activate and stop tire spin, matching rotation across the axle. Such a wonderful feature... getting stuck could be a thing of the past! ;)
  2. May 11, 2011 at 5:27 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    hey sorry for kinda butting in but i have just 1 quick question
    i know what lockers esentially do but what do they help in i.e mud/rock/snow?
  3. May 11, 2011 at 5:40 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I Have a 2WD 07 TRD OR and my locker will engage at low speeds ~5~10mph. If you are over that it will blink at you all day untill you are slow enough to engage. Now in mud especially if one tire loses traction and keeps spinning the other tire will not(or not much). When the locker is engage you are ensuring that both tires are spinning.
  4. May 11, 2011 at 5:45 PM
    David K
    For my four wheeling, they greatly increase the truck's climbing ability on STEEP GRADES with LOOSE ROCKS or DEEP RUTS.
    If one tire gets over loose stuff or over a deep rut (and it is no longer on the ground... you LOSE that entire axle drive... because the loose tire will spin, and take the power away from the traction tire. 4WD helps, but if one of the front tires also looses traction, then you are stuck... or can't climb any more.
    A locker (or good traction control) will match (or try to match) tire rotation across the axle so the good tire gets an equal share of torque from the differential.
  5. May 11, 2011 at 5:51 PM
    bowhunter11199
    oh i c. thanks man. ya i tried it in 3.5ft of slushy snow yesterday and it did make much if any difference cuz my tires are just to wide to cut through slushly snow
  6. May 11, 2011 at 7:42 PM
    Tarheelz2350
    Tarheelz2350 Well-Known Member
    Jon
    Dallas, NC
    10 MGM 4x4 TRD O/R DC
    Bilstein 5100's F/R, Tin Snip mud flap mod, Partial Debadge, Rear Diff Breather Mod, Rear Spring TSB, 265/75/16 Cooper Discoverer AT3's, Devil Horn's courtesy of Andres
    Nice thanks for the visual aids. They make the owner's manual a little easier to understand. Good write-up.
  7. May 11, 2011 at 10:36 PM
    Manchu
    Manchu Member
    Eugene Or.
    SR5
    Old man Emu lift Cbi Moab 2.0 front bumper Goodyear Duratrac Warn M8000 All-Pro pack rack CVT Mt. Shasta
    Thanks David,
    I did start by looking for something in the rig that would give me a clue. My visors look like this. As well as the passenger side.
    No where in the truck that I could find had any such instructions. The Owner's Manual would probably have all that I would need.
  8. May 11, 2011 at 10:40 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    They were in the driver's side , somebody got rid of the card
  9. Oct 15, 2012 at 8:48 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    not sure about this. mine will engage in any drive mode 2hi, 4hi, or 4lo. just sometimes have to rock it into place
