Locking Differential question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thundjet, Dec 17, 2011.
  1. Dec 17, 2011 at 3:22 PM
    Thundjet
    Thundjet [OP] Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Does the locking differential "lock" in 4wd high?
  2. Dec 17, 2011 at 3:26 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    No. RTFM! ;)
  3. Dec 17, 2011 at 3:26 PM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    It will only lock in 4wd low. There is a mod though where it can be turned on anytime. Look in the cheap mods section. I think it's in there.
  4. Dec 17, 2011 at 3:29 PM
    SoJersey
    SoJersey Man.As.Prescribed
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension ARE Z-Series More coming soon...
    i am looking to do the locker mod tomorrow. does it idk hurt anything by doing so.. i'd only use it in 4hi other then 4lo...
  5. Dec 17, 2011 at 5:58 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Remember, you do have TRAC in H4 (limited slip on all 4 tires)... are you sure you need the locker in H4?
    In L4, you have A-TRAC whick gives 'near' locker-like traction on ALL 4 tires, not just the rear. It is amazing! I have had 2 other Tacomas with the rear locker, and the A-TRAC out-performs what they could do... just fyi.
  6. Dec 17, 2011 at 6:01 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I don't see any information on his truck...how do you know he's not driving a 2004 OR Prerunner?
  7. Dec 17, 2011 at 6:07 PM
    David K
    I see it fine, he has a 2012 Off Road... and from his post, it's a 4WD.
  8. Dec 17, 2011 at 6:20 PM
    jandrews
    You're looking at the first reply, not the OP.
    To the OP: The locker in these model trucks only operates in 4Lo from factory. There is some custom wiring that can be done to allow locker operation at any time. I believe someone linked it earlier.
  9. Dec 17, 2011 at 6:21 PM
    Thundjet
    Sorry guys, truck I am looking at to purchase is a 2012 TRD V6 auto. Doubt it will ever see off road but since our streets are pretty much solid ice or snow (live in Alaska) from Nov til the first of April was wondering how the truck would perform on the streets in 4H if the rear end didnt lock up.
  10. Dec 17, 2011 at 6:22 PM
    jandrews
    Generally speaking, a locker on ice is a *bad* idea.
  11. Dec 17, 2011 at 6:23 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    4wd is enough for snowy street driving
  12. Dec 17, 2011 at 6:27 PM
    jandrews
    "Corkscrew effect".
    There are certain situations where they can be helpful, but try to avoid their use if other traffic is around.
