locking differential
Discussion in 'Technical Chat' started by matthew5olson, May 25, 2009.
  1. May 25, 2009 at 12:59 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    This may have been covered already but I could not find it. If I made my locking differential so it worked in 2 wheel drive how fast can I go. It makes sense that there is no speed limit that would be dangerous to my differential. Any thoughts?. Anybody who has modded theirs and drove fast with it.
    I just thought it would be something nice to have for those couple times when your at a stoplight and the guy next to you in a ford ranger thinks he's got the better truck. Would this really help at all in a drag race anyway? I do have a stick so I can spin the tires real good (not sure how much the autos can, never owned an auto truck).
  2. May 25, 2009 at 1:02 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  3. May 25, 2009 at 6:30 PM
    Mon Leb
    Mon Leb Tacoma's Quest!
    St-Jean-sur-Richelieu, Quebec, Canada
    09' 4X4 SR5-TRD Sport, Leather, BackUp camera
    Chromed Bull-Bar Westin. Sport pedals. Round side steps bars. Stainless Steel Exhaust Tip 4WD Switch Light Mod Door Sill Protectors
    It's not really clear to me that mod. Do we have to add a switch somewhere to turn it on/off besides the relay? Or is it always on? (locked):confused:
  4. May 25, 2009 at 6:34 PM
    matthew5olson
    matthew
    pittsburgh, PA
    IDK I looked on other forums and I think mine is different (1st gen) I just have to ground one of my wires aparently. It looks like 2nd gens have to buy some relay or something.
  5. May 25, 2009 at 6:58 PM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    I did the mod to mine with teh relay and it works great . Been to the track with it and running like 9.40 in the 1/8 with it . Ive done at least 90 with no problems . Only problem i had at the track is i still blew the tires away at the line after doing a burnout and then had nothing but wheel hop for like the first 60 ft or so . Thats cause im supercharged.
  6. May 25, 2009 at 7:32 PM
    matthew5olson
    matthew
    pittsburgh, PA
    monte1985 what track was that. I would like to try a few 1/4 mile runs but have no Idea where to go. How much of a difference do you notice off the line with your diff locked.
  7. May 25, 2009 at 7:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Sorry man didn't realize you had the first gen. I think there is a way to do it but don't hold me to it.
  8. May 25, 2009 at 7:45 PM
    matthew5olson
    matthew
    pittsburgh, PA
    There is and its actually easier, no parts to buy just one wire to ground
  9. May 25, 2009 at 7:48 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Thought so, glad you found what you needed.
  10. May 25, 2009 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
