Locking differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PM4x4, Sep 22, 2019.
  1. Sep 22, 2019 at 6:31 PM
    PM4x4
    PM4x4 [OP] Active Member
    Pat
    2012 Black Tacoma TRD
    Hi I am looking for somewhere to start. My locking differential indicator just flashes when I try to use it .
  2. Sep 22, 2019 at 9:18 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    are you in 4wd?
    whatstcp likes this.
  3. Sep 22, 2019 at 9:19 PM
    eon_blue
    Azusa, CA
    If you have 4wd you have to be in 4lo for the locker to engage. It usually takes a few feet or more of driving until it locks.
  4. Sep 23, 2019 at 10:04 AM
    PM4x4
    Pat
    Yes I was in 4L but was stopped when I engaged it. This was my first time I’ve tried to use it. So after I engage it do I need to start rolling while light is still blinking?
  5. Sep 23, 2019 at 10:05 AM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Yes try that. Roll forward a bit and see if the light locks in solid.
  6. Sep 23, 2019 at 10:06 AM
    PM4x4
    Pat
    Ok thanks I will .
  7. Sep 23, 2019 at 10:07 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yep sometimes it takes movement for mine engage and disengage
  8. Sep 23, 2019 at 10:07 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    it sometimes helps to turn the wheel slightly to line up the splines
    Jerneyman likes this.
  9. Sep 23, 2019 at 11:54 AM
    atompson
    atompson Well-Known Member
    Andrew
    Dallas, TX
    Tompson
    None.
    The only time I've engaged mine, it wouldn't disengage. For some reason I had the bright idea to shut the truck off and restart. Doing that disengaged the rear diff locker. Just in case you have the same experience.
  10. Sep 23, 2019 at 8:19 PM
    PM4x4
    Pat
    Thanks I’ll see how it goes and try some of these .
  11. Sep 24, 2019 at 2:42 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I would try the slow roll like the others said.
    I've also put mine into neutral before to relieve tension on the driveline, usually because of the angle or position I've got the truck in at that moment on the trail.
