Locking doors with keyless entry
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AkJohnE, Jun 22, 2022.
  1. Jun 22, 2022 at 7:17 PM
    AkJohnE
    AkJohnE [OP] Well-Known Member
    2021 Tacoma
    Some of you may be interested in this. I discovered a way to lock my truck while its running.
    When you exit a running vehicle, push the door lock button on the armrest and the door open button on the pillar and you can now close the door and it remains locked.
    During the winter here in AK its nice to let the truck warm up and have it locked, also handy in the summertime and if going into a store for something quick and you want to leave it running. You may have to change your door lock settings. Mine are set so they do not automatically lock when I start driving and all doors unlock at the same time.
    Its a nice feature when its minus 40 outside.
  2. Jun 22, 2022 at 7:25 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I may be a noob when it comes to labels of vehicle components, but please explain further.
    I know the Door Lock button on the armrest, but I'm not clear what you mean when referring to the "door open button on the pillar".
  3. Jun 22, 2022 at 7:29 PM
    caribe makaira
    Caribbean, Puerto Rico
    OP, have you looked at the wear n tear of the door lock mechanism?
  4. Jun 22, 2022 at 8:24 PM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    I think he is talking about the press switch inside the door frame that tells the truck if the door is open or not. if you are sitting in the drivers seat with the door open reach back into the chassis door frame with your left hand and you will feel the rubber cover over the switch. the door itself pushes in on the switch when the door is closed.
    davidstacoma and OmahTako like this.
  5. Jun 22, 2022 at 8:32 PM
    caribe makaira
  6. Jun 22, 2022 at 9:50 PM
    AkJohnE
    2021 Tacoma
    Yes the switch in the jamb, on the pillar right below the latch.
  7. Jun 22, 2022 at 9:51 PM
    AkJohnE
    2021 Tacoma
    Yep
  8. Jun 22, 2022 at 9:52 PM
    AkJohnE
    2021 Tacoma
    12k miles so no wear on the switch, works fine? Maybe missing your thoughts on this
  9. Jun 22, 2022 at 9:54 PM
    AkJohnE
    2021 Tacoma
    I think this would only be pertinent if you have a smart key, which I am not that fond of.
    Mikeh80 likes this.
  10. Jun 22, 2022 at 9:58 PM
    caribe makaira
    The mechanical part, where the door locks to the cab frame. Since the mechanism is closed and you press the door.
    OmahTako likes this.
  11. Jun 22, 2022 at 10:03 PM
    AkJohnE
    2021 Tacoma
    Confused, is this a question?
  12. Jun 22, 2022 at 10:17 PM
    caribe makaira
    Clarification to prior question...
  13. Jun 22, 2022 at 11:24 PM
    avn
    avn Well-Known Member
    A
    CA
    2022 TRD OR
    Should have no issues, it’s basically the same thing as when you lock and unlock your vehicle when it’s on and you’re sitting inside of it. Your truck was designed to do that. Default is set to unlock when put into park and lock when put into drive out of the factory.
    Unless I’m misunderstanding what you’re saying.
  14. Jun 22, 2022 at 11:42 PM
    AkJohnE
    2021 Tacoma
    Ok, I am not tripping the door lock mechanism. I am just pushing and releasing the button and operating the switch that indicates to the vehicle whether the door is open or closed. The only thing the operator would notice is the interior lights go on/off. However the switch is also communicating with the vehicle's computer. IOW, you can lock unlock the doors from the drivers seat when the door is closed. As soon as you open the door you can no longer lock the door if the engine is running. If you hit the lock button it will momentarily lock the door and then immediately unlock it. Pushing the button on the jamb defeats this and allows you to lock the doors with the engine running.
    TacoSupremo19 likes this.
  15. Jun 23, 2022 at 12:02 AM
    caribe makaira
    So your saying that after "fooling" the ECU, the mechanism doesn't actuated and your not smashing it against the receiving end of the door frame?
  16. Jun 23, 2022 at 4:34 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I press the door jamb switch to stop the chime when I have the door open and I have the ignition in ACC or ON so it's probably the same thing. Nothing mechanical happens it's just an acknowledgement.
  17. Jun 23, 2022 at 8:10 AM
    AkJohnE
    2021 Tacoma
    Not smashing anything just simply closing the door. I doubt I could fool the ecu... I am not sure why it works, but it does.
  18. Jun 23, 2022 at 4:02 PM
    caribe makaira
    You left out the OP presses the lock button, so no new info there...:smack:
  19. Jun 23, 2022 at 4:12 PM
    caribe makaira
    So you haven't looked at or heard the lock actuate at all. I ask, because the door unlock input is inside the lock mechanism.
    Once you press lock, the locking solenoid actuates making a distinctive sound. This in turn prevents the door lock mechanism from engaging the frame receiver.
    I'm thinking there's a part inside the locking mechanism that doesn't engage to prevent damage. Maybe:stirthepot:
  20. Jun 23, 2022 at 4:19 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Seems simpler just to move out of AK to someplace with a tad more moderate climate :)
