Locking doors with truck running
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joker8824, May 3, 2020.
  1. May 3, 2020 at 7:23 AM
    Joker8824
    Joker8824 [OP] Well-Known Member
    2014 MGM DCSB TRD Sport
    In my work truck I’ve got a two piece removable key chain to be able to remove the fob and lock the truck with it running.
    I got the same keychain for the Taco and learned today the doors won’t lock with it running via the key in ignition.
    is there something I can change to make this work or is it a safety feature I can’t bypass?
  2. May 3, 2020 at 7:30 AM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    They think of everything don't they ? But you can lock the doors from inside when your driving right ?
    It could be the fob outside and the key inside is the issue. Seems strange though.
  3. May 3, 2020 at 7:36 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Have you tried hitting the door lock on the passenger door and then closing? Do it with the window down in case it doesn’t unlock for you
  4. May 3, 2020 at 7:42 AM
    Joker8824
    Haven’t tried any other ideas yet. Was heading to work and hopped out at a gas station for a drink. Left it running like I do my work truck every day and came out to open the back door and it was locked.... wouldn’t unlock and freaked me out a second until I realized the driver door was unlocked.
    So hitting the lock button never worked. I sat in the truck with it running and tried using the fob to lock the doors and it wouldn’t lock.
  5. May 3, 2020 at 7:53 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I can leave my truck running, and use an extra door only key I had made to physically lock it.
  6. May 3, 2020 at 9:11 AM
    Joker8824
    I guess I could do that with carrying an extra key.
    since I’m wanting this feature it kinda makes sense to go with the 12V system now for remote start since it has the pit stop feature ....
  7. May 3, 2020 at 9:14 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Or you could go down the Techstream rabbit hole and reprogram it yourself
  8. May 3, 2020 at 10:17 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    I use a key without the chip
    It will lock door but not start truck
    I do this in winter to warm it up
    I married my tacoma likes this.
  9. May 3, 2020 at 10:20 AM
    Muddinfun
    Muddinfun Well-Known Member
    From the factory, the fob won’t work when the ignition is on. That’s 1 of the problems with the remote start that uses the OEM fob where you push lock 3 times to remote start. After you remote start it that way, you have to use the key to unlock it.
    I think your only choices are
    1. Carry a 2nd key
    2. Aftermarket alarm and fob
    3. Hidden waterproof momentary switch in the grill.
    Joker8824[OP] likes this.
  10. May 3, 2020 at 11:01 AM
    Joker8824
    Thanks for that info. Answered a lot of questions and makes the 12V remote start that much more appealing, as it looks to solve 2-3 issues for me in one shot
    Muddinfun[QUOTED] likes this.
  11. May 3, 2020 at 11:33 AM
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    I think is worth it for you to look into aftermarket, Viper, Python, Compustar, etc. All these systems offer a "Pit Stop Mode" is a mode that allows the vehicle to continue to run without the key in the vehicle. This way the vehicle remains running WITHOUT the key in the ignition and it allows you to exit the vehicle while it's running and arm the alarm.
    Cheers!
    Rick
    303tacoma and Muddinfun like this.
  12. May 3, 2020 at 11:50 AM
    Joker8824
    If I understand the 12v solutions system they offer the pit stop mode.
  13. May 3, 2020 at 5:11 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Leave one key in the ignition and truck running, hit the automatic locks to lock all the doors, manually flip the unlock lever on your door, get out, use your spare key to manually lock the driver's door with the key hole :)
    That's how I do it
  14. May 3, 2020 at 6:08 PM
    Soylent Green2012
    jake
    Apopka, Florida
    yup What He said ^^^^^^^^
  15. May 3, 2020 at 7:54 PM
    241240 Sir Lurks-A-Lot
    09 base double cab 4.0 MT
    Sat my fat rear end in it.
    During the process of adding a cheap aftermarket fob to my taco, I discovered the computer disables the interior power unlock switch after the doors have been locked for a little while. However, the power lock and unlock electrical switches that are activated by turning the key cylinders in the front doors seem to work all the time.
    Toyota's software folks really put a lot of effort into programming arbitrary scenarios in which the power door locks won't work.
  16. May 3, 2020 at 9:03 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Lol, you could always try sanding the key down??? I'm joking of course, but here is a fun fact for you that's kinda related and kinda scary. The key I use everyday is now so worn down that I can pull it out of the ignition while the truck is running, yet it still starts the truck. I know it's the key that wore down and not the ignition because I can't do that with my 2 spare keys or valet key. So I guess our ignitions aren't too picky, lol!
  17. May 3, 2020 at 9:17 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    Yep I use it just about everyday. Before leaving the truck you press the button for 3 seconds, removed the key and lock the vehicle with the fob while doing the errand. Unlock the truck, stick key back into the on position and drive away normally.
    Joker8824[QUOTED][OP] likes this.
  18. May 3, 2020 at 10:22 PM
    Muddinfun
    Worn keys are really hard on the lock. You’re forcing the lock to turn when the wafers aren’t perfectly aligned. One of these days, the lock isn’t going to turn with any of your keys.
  19. May 3, 2020 at 11:56 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I never thought about that. You mean the door lock or ignition? I RARELY if ever use the worn key to lock the door.
  20. May 4, 2020 at 5:36 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Check local laws first. In many states it’s a ticket to leave an unmanned vehicle running, even on private property. Exceptions are mail jeeps etc but no private vehicle has an exception.
