Locking Fuel door mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elutheros, Oct 28, 2010.
  1. Oct 28, 2010 at 12:57 PM
    elutheros
    elutheros [OP] Active Member
    Copperas Cove, TX
    07 Crew Cab
    Bike rack above bed Locking Fuel door
    Since Toyota did not offer the option, I thought I would take a stab at creating it. I made a couple mistakes along the way, but I'm satisfied with the results. Now my fuel door is locked shut until I push a button in the cab to open it. I also have an emergency manual release for the door which is accessed through the useless storage bin behind the fuel door in the bed.
    I'm sure others will refine this mod, and I hope this helps you make it better.
    First, get yourself the electric motor/solenoid that is used to lock the fuel doors on many late model cars. I chose one from a Mazda Millenia because it was handy. I thought I would be able to modify the locking tab from the Millenia door for my project, but I had to make a new one. The Millenia solenoid proved to be about half an inch too long--it interferes with the storage bin, so you might look for others that are slightly shorter.
    Next, remove the storage bin from the bed near the fuel door and remove the pin your door's spring clip fastens to when it is closed. Remove the spring clip from the fuel door and hang onto the screw. The Millenia solenoid has a spring built into the mount that kicks the door open when activated. Look for something similar when you get one or you will have to add a spring somewhere to open the door. I used the solenoid mounting plate to mark the holes needed. I eventually slotted the holes so I could have a range of adjustment for the solenoid to keep the door closed flush with the body. The plastic surround for the fuel filler is easier to drill.
    Fabricating a new tab for the solenoid to lock into took quite a bit of trial and error. I eventually found a bracket I cut down to size and bent as required. The red marker helped me see where the hole needed to be for the pin from the solenoid to engage. You can see I tried to used an alternate mounting point, but the original mount/screw on the door works best.
    The wiring just uses a free blade in the engine compartment fuse box which is "hot" all the time (added and inline fuse) and used a ground from the trailer hitch connections. Used a rubber grommet on the back of the cab as the exit point and covered the exposed wire with rubber tubing to protect it and isolate it from all that fuel stuff.
    I had this old RSCA OFF switch lying around and found that two of the poles provide a "momentary on" connection, so I just used it as my switch. Works great.
    If you have suggestions or questions, let me know.
  2. Oct 28, 2010 at 1:00 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    pics no worky
  3. Oct 28, 2010 at 1:03 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    sounds nifty, but i'd like to see some pics :p
  4. Oct 28, 2010 at 1:03 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    What's up with the pics
  5. Oct 28, 2010 at 1:06 PM
    JimBeam
    JB
    2015 Tundra
    they dont work :laugh:
  6. Oct 28, 2010 at 1:24 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You have some weird picture code. The image tags are all screwed up. I fixed them here.
  7. Oct 28, 2010 at 2:06 PM
    elutheros
    Copperas Cove, TX
    07 Crew Cab
  8. Oct 28, 2010 at 4:25 PM
    The1youluv2hate
    Peps
    SAnta Paula CA
