Locking gas cap causing check engine light to come on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by daylight, Jan 1, 2022.
  1. Jan 1, 2022 at 10:00 PM
    daylight
    daylight [OP] Member
    gilbert
    4 runner
    none
    howdy bought locking gas cap for 2008 but the engine light came. so l replaced the o ring on the cap for a better seal it was a no go. so what will happen driving with the engine light on?
  2. Jan 1, 2022 at 10:13 PM
    Waasheem
    Waasheem
    2007 xrunner
    It seems to be hit or miss with them. You could try to return or exchange for another.
    2 issues I can think of running with a check engine light lit. 1, dependent on your local laws, you could fail smog or inspection. 2, if another reason for it to light up arises, you won’t know which would leave you constantly wondering.
    The one I got is stant 10509.
  3. Jan 1, 2022 at 10:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Spend the money on a OEM cap. Anything less and you risk random evap codes coming and going
    blu92in99, Naveronski and Geeves77 like this.
  4. Jan 2, 2022 at 4:49 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    Did you clear the CEL after changing O ring?
    I guess it is hit or miss. I’ve been using a Honda locking gas cap for the past year and no CEL.
    FWIW 2010 Element
    I use it since my truck is outside all the time
  5. Jan 2, 2022 at 7:27 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Is the CEL due to the gas cap though? Unless you can read the code off OBD, you won't know for sure.
    Dm93 likes this.
  6. Jan 2, 2022 at 8:49 PM
    TacoTuesday1
    FL
    been running a Stant locking cap 1yr+ with no CEL
    nudavinci64 likes this.
  7. Jan 2, 2022 at 8:52 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Same here.
