Locking Gas cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kahanabob, Mar 5, 2022.
  1. Mar 5, 2022 at 12:16 PM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i googled this and can't get an answer, is there a locking gas cap that will work on my 2016 TRD 3.5?
    confused, this vented not vented issue. every where i look and enter my truck info it says not compatible.
    we are at $5. a gallon here in hawaii and think it is time to lock it up.
  2. Mar 5, 2022 at 12:19 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I've tried several and finally was able to order mine on O'reilly's website. The part# 10504.
    It says it does not fit my 2021 TRD Sport...but it did!
    https://www.oreillyauto.com/detail/.../a/153546/automotive-truck-2021-toyota-tacoma
    No check engine light and I've refueled at least 3 times since install.
    EDIT: you have to select the store closest to you. Not sure if there's one in HI and I would hope they ship to the 808.
    Ed
  3. Mar 5, 2022 at 12:21 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    for theft, the neck has the anti-siphon hose spring in it and a locking cap won't prevent a hole drilled in the tank if they want it bad enough
    to prevent contaminates getting pored in, see above^
    9th likes this.
  4. Mar 5, 2022 at 12:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Damn.
    BTW most thieves are going to drill through the bottom of the plastic fuel tank and drain it all instead of siphoning it through the filler neck which should have an anti-siphon feature.
    9th likes this.
  5. Mar 5, 2022 at 12:22 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
  6. Mar 5, 2022 at 1:25 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    it says it fits my 2016, there is an o'reillys here and they are in stock.
    thanks
  7. Mar 5, 2022 at 1:32 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  8. Mar 5, 2022 at 2:05 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    BONUS!
    Glad I can pass on what helped me from the TW.
    Ed
