Locking Gas Door install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eAreEyeSee, Jan 19, 2014.
  1. Jan 19, 2014 at 11:02 PM
    eAreEyeSee
    eAreEyeSee [OP] Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
    Here's the write up for those of you who have purchased or are interested in getting my locking gas door kit. Note this is for the 2nd gen Taco's.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/311761-locking-gas-door.html
    Please note If you have one of the newer 2nd gens and don't have the bed storage pockets that would allow you to gain access behind the gas door you can go from under the fender liner in which case this its not quite the easy bolt on project. Some members have done it but it does add some difficulty so just a heads up if your reading this to see whats involved.
    The standard round button, fuse tap, and spring are included. You'll just need wire, some assorted wired connectors, and zip ties.
    • Install and wire up your momentary button. I started with a basic button and eventually switched to a VW button I got from ebay for about $14. It's an illuminated button but I didn't feel like wiring that part up. Basically one wire of the actuator goes to ground and the other wire will go through your momentary button to a constant 12+ or to ignition controlled 12+. There are random rubber plugs under the seats in the cab that you can cut a small slit into and use to run the wires outside the cab and to the bed of the truck.
    • Remove the bed storage pocket and reach in and pinch together the top/bottom barb like prongs and wiggle out the post toward the gas cap. I was able to do both of these steps while standing on the outside of the truck and just reaching over the bed rail.
    • Next, pull your wires from the dash button through the pocket and connect them to the actuator. You can use female bullet connectors to match the male plugs on the unit or cut them off and use crimp caps, solder/ heat-shrink or whatever you like. The blue wire on actuator gets connected to ground and the green goes to 12+ through your momentary button.
    • Remove the 14mm nut off the unit and feed the threaded end of unit through the empty square hole left by the removed post. I might be a tight fit and but it should go through. You might have to give it some sweet talk or lightly file the hole just a bit. Unscrew the factory door clip and replace with the machined latch. The slot on the latch for the screw allows you to adjust it fore and aft so you can get it as close to the nut without hitting it while the door swings open/close.
    • Press the spring onto the lower rubber bumper to kick the door open when unlocked. It should press on with little effort but also be snug enough to stay put in the rubber. I also stuck a piece of electrical tape on the door to protect the paint.
    That should be it.
    tacopearl, lo2hi, Travisp10 and 3 others like this.
  2. Jan 19, 2014 at 11:35 PM
    d2mikey
    d2mikey Member
    California
    '13 Tacoma Access Pre-runner SR5
    Interested as well.........nice job
  3. Jan 20, 2014 at 12:21 AM
    HandOfGod
    HandOfGod Well-Known Member
    Tacoma TRD 4x4
    Stock
    That is a great idea. Add that to the mod list. I just need to come up with the money now ;)
  4. Jan 20, 2014 at 12:37 AM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    And you lost me at broncos :puke:
  5. Jan 20, 2014 at 3:49 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Nice write up. I see a lot of guys worried about locking gas caps and this mod. Guess I just don't live in a place where stealing gas through an unlocked gas cap is a problem. Is there a reason you go with a locking gas cap plus this mod?
    Not being negative, just wondering. Like the idea though.
  6. Jan 20, 2014 at 7:51 AM
    eAreEyeSee
    Eric
    Aurora CO
    Ive personally have never had a problem with vandalism or theft. It was just something I wanted to do. Yes, I realize its only a deterrent and if somebody really wants to get in then they will. I guess the same could be said for locking your doors when leaving the truck but it doesn't mean I'm going to stop doing it.
    I currently don't have the locking cap and the locking door on the truck at the same time. Some of those pictures were from when I was test fitting the thing.
  7. Jan 20, 2014 at 1:46 PM
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    What if you already have a Tail gate lock already wired to the door sill wires? Can we just tape the the wires further down from that?
  8. Jan 20, 2014 at 3:57 PM
    eAreEyeSee
    Eric
    Aurora CO
    Yessir. That's exactly what I did but my write up doesn't show that. I did the write up as a clean virgin install so it would be less confusing and more clean looking.
  9. Feb 5, 2014 at 9:54 AM
    d2mikey
    d2mikey Member
    California
    Just wanted to post a follow-up to my installation of Eric's locking gas door.
    I have a 2013 Access Cab so access to the gas filling area from behind is non existent. But with the pulling of a couple of wheel liner retaining pins, I was able to reach up behind the liner and remove (some challenge) the existing "post". After that, installing the locking solenoid bracket/mechanism was fairly easy. Eric did a very nice job and the solenoid/plunger assembly.
    Running the wires went quite well. The main electrical harness to the rear of the vehicle runs along the frame nearby and up through the floor just underneath the driver's seat. I ran my new harness along side the existing and up through the same plug under the driver's seat. Then ran the wiring harness further under the door sill and into the emergency brake panel area.
    Finding the right wires to tie into was a little more of a challenge. The color coding on my '13 AC was as Eric described but the two wires were in separate harnesses going up into the door. Actually, to be more specific, they are in separate harnesses going into the door but tied and taped together near where they exit near their respective harness plugs. Once I figured that out, finding both wires needed and connecting into them was quite easy. I did cut back some of the shielding around the harnesses to expose more of the wires in the harness and allow easier access to use the splices. Wire length for my AC was perfect.
    Also, I left the little adjustable bracket that attaches to the gas door with a very slight interference to the plunger nut. This eliminates the need for the magnet to hold gas door closed for the plunger to line up upon closing.
    As Eric described, the solenoid does make a slightly louder sound than the door lock solenoids. When I get a chance, I was going to try and wrap the solenoid/plunger assembly with a bit of insulation to see if that would quiet it down some. It is very hollow up inside the wheel well with no insulation so any noise is going to appear loud just from the echo.
    Nice job Eric.
  10. Feb 5, 2014 at 10:02 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Great mod and writeup, but no thief is going to bother with going through the door. These scumbags drill a hole from the bottom and steal the gas that way.
    GilbertOz likes this.
  11. Feb 6, 2014 at 10:44 AM
    eAreEyeSee
    Eric
    Aurora CO
    d2mikey,
    Thank you for the kind words and your feedback on the effort required for install on trucks without the pockets. I'm glad it all worked out for you and you got it working.
    I recently happen to come across a random piece of foam at work about the size of 8x8x1.5 and figured why not try it. I folded it in half and shoved in the fender area so it sorta wedged between the actuator bracket and the fender liner. I must say it's quite a bit quieter now by just having the foam to dampen the sound. Rather than the hollow clack, it's now more of a dull thud. Maybe you could try something similar. I'll probably experiment some more once it gets above freezing here.
  12. Feb 6, 2014 at 10:55 AM
    iJDub
    iJDub Well-Known Member
    Key for gas cap and locking door. I guess with gas prices these days...
  13. Feb 6, 2014 at 11:23 AM
    eAreEyeSee
    Eric
    Aurora CO
    Yeah, I guess I should take new pictures for the write up so it doesn't look like that huh? It would be too much to assume people would figure out the key cap is before the door lock mod and the pictures after the mod have the regular cap back on. It makes it look like I live in the super hood when actually I'm in a nice area and have never had any problems.
  14. Feb 26, 2014 at 9:41 AM
    eAreEyeSee
    Eric
    Aurora CO
  15. Feb 26, 2014 at 11:36 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    That's so cool!
  16. Mar 4, 2014 at 8:59 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    sub, great write up.
  17. Mar 4, 2014 at 9:07 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Bravisimo and patbegley like this.
  18. Mar 4, 2014 at 9:43 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Awesome.
    I need to do this
    :beer:
  19. Mar 5, 2014 at 8:23 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Great write up. Seems like there is never and end to mods that we can do to our tacomas.Will put this on my list of mods to do. Thanks again.
  20. Mar 5, 2014 at 2:17 PM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    This is fact but....it will protect you from the as*hol* who wants to drop sugar or something in you tank! There are a lot of loons out there and it doesn't take much to piss them off.
    Nice product and write ups!
