Locking hitch pin
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cnasianfire, Nov 18, 2018.
  1. Nov 18, 2018 at 6:48 AM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I have tried 2 locking pins and none are long enough to lock. What do y'all use?
  2. Nov 18, 2018 at 6:52 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    stizo likes this.
  3. Nov 18, 2018 at 6:55 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Great thanks!
  4. Nov 18, 2018 at 6:56 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I use the ones made by Bolt that use your truck key.
    Bentrodder and largemouthdmb like this.
  5. Nov 18, 2018 at 6:59 AM
    Cnasianfire
    Charles
    Wilmington, NC
    That's really cool.
  6. Nov 18, 2018 at 8:13 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I've had a stainless model from Home Depot for 10 years and it's been great. It gets salt water on it all the time and has never given me any trouble. I believe it was around $20.
  7. Nov 19, 2018 at 4:42 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Grease the hell out of your locking hitch pins...... otherwise they'll lock so well only a grind will take them of.
    Trust me.. I know
    Alexely999 likes this.
  8. Nov 21, 2018 at 7:07 AM
    Cnasianfire
    Charles
    Wilmington, NC
    I found one that fit! I didn't think about the greasing part. Great advice. Going to go and do it now before I forget.
  9. Nov 22, 2018 at 5:37 PM
    GT_Charlie
    GT_Charlie Well-Known Member
    We have bought three of whatever Academy has, and they work well. I expect that Home Depot has much the same thing. Keep the key on the ring with your truck key and you never have to wonder where it's at.
    Charlie
  10. Nov 22, 2018 at 6:49 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    That's the only way I take mine out. Lol.
    BlueC0ma likes this.
  11. Nov 23, 2018 at 3:50 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    I'm using a Connor stainless steel locking hitch pin. Works just fine but the O ring that seals the locking mechanism is lacking. I replaced the O ring with a larger one and trimmed it to fit exactly. So far so good....
  12. Nov 23, 2018 at 4:33 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
  13. Nov 23, 2018 at 4:54 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I don't think grease is the best protectant or lubricant in this case as it will probably attract and hold all sorts of grime. Maybe Fluid Film or a dry lubricant would be better suited....??
  14. Nov 23, 2018 at 5:03 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I spray mine intermittently with a thin coat of silicon lubricant and that works fine, doesn't hold any dirt. I also highly recommend spraying some additional lube into the lock tumbler mechanism from time to time, and then work the key in and out a few times.
    tgordo49 and Crow Horse[QUOTED] like this.
  15. Nov 23, 2018 at 6:14 AM
    08TacoTrD
    08 TRD Offroad
    That link didn't work for me but it's funny when looking at trailer locks. Most of them just lock the actual coupling but if I really wanted the boat I could u bolt the coupling and put on a new one.
  16. Nov 23, 2018 at 6:17 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I'm not following...Can you explain?
  17. Nov 23, 2018 at 6:18 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
  18. Nov 23, 2018 at 6:19 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    He means you can just unbolt the tongue from the trailer and bolt a replacement on with no lock.
    It’s true, but the point of a lock is never to 100% deny theft, just to make it harder and encourage the thief to move on to an easier target.
  19. Nov 23, 2018 at 6:21 AM
    Edmontontaco
    Edmontontaco Well-Known Member
    Alberta, Canada
    2016 Black TRD Sport
    doublethebass likes this.
  20. Nov 23, 2018 at 6:30 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I think I understand.... On my trailer (kayak trailer), when hooked up, I have the above pictured receiver lock and a lock on the trailer tongue. When parked and separate from the truck, I use a tongue lock, an additional padlock on the tongue release, a wheel lock and 11mm chain from frame to a buried ground anchor. Is it defeatable? Sure but I wanted to make it a major PITA for thieves and that could prove to be a deterrent....
