Locking hubs on rear of 99 Tacoma rwd
Discussion in 'Technical Chat' started by InshoreTrekker, Mar 17, 2017.
  1. Mar 17, 2017 at 10:06 AM
    InshoreTrekker
    InshoreTrekker [OP] Member
    Alaska now... Soon to be Florida for the fish.
    I have inherited a 1999 Toyota Tacoma rwd auto xmission. If possible I would like to install locking hubs to allow the vehicle to free wheel while towed behind our motor home. Drive shaft disconnects and tranny lube pumps do not seem as viable as simply disconnecting the rear axles. Any suggestions or feed back such as what axles are required for the conversion would be appreciated?
    Thanks in advance.
  2. Mar 17, 2017 at 1:04 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I've heard that serious Jeepers do this, for the same reason.
    I assume they are using a full-floating Dana axle.
    Thats all I know
  3. Mar 17, 2017 at 1:25 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just how far do you Tow this vehicle ??
    If your wanting Locking Hubs I would think it is for very short distances and your doing quite often.
    Which would make pulling the Drive Shaft a pain .
    I never researched but by now I am sure some Chinese company might very well make a kit for what you need .
    First your going to need a free floating rear axle .
    With some custom made axles .
    Then you need to decide just what brand of Hubs your going to use .
    I know at one time Warn sold a kit for rear wheel hubs For the Jeep full floating axle still seems to be listed
    If you can do all the install and axle swap yourself it might come in under $2000.00 if you need to pay labor it will be expensive .
    If this is what you want it most likely can be done but not cheap
  4. Mar 17, 2017 at 1:43 PM
    InshoreTrekker
    Tan4X4 and Wyoming 09, thanks for the feedback. I am looking at either Warn or Aisin hubs. http://aisinaftermarket.com/English/Product.php?product_id=19
    Going to go to Toyota and price out full floating axles, etc., if they have them. Will post results as well as photos of truck and project when finished.
  5. Mar 17, 2017 at 1:51 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    A full floating axle is a complete axle assembly drum to durm
    Not a axle shaft to slip in what you have now.
  6. Mar 17, 2017 at 1:59 PM
    InshoreTrekker
    Today is for sure a rain on the parade day.
  7. Mar 17, 2017 at 2:01 PM
    InshoreTrekker
    Can locking hubs be installed on "semi-floationg" axles? I'm thinking no.
  8. Mar 17, 2017 at 2:49 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
  9. Mar 18, 2017 at 2:09 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    There you go OP if you want your locking hubs .
    This is the way to go
    You only need to source a few parts and it works with the axle housing you already have
  10. Mar 18, 2017 at 9:31 PM
    InshoreTrekker
    Wyoming09 Thanks for the thread... However, can't figure out what who or how! Any more info??
  11. Mar 18, 2017 at 9:45 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    My old M38A1 68 jeep had a full floater Dana 44 rear with Warn Gold Premium locking hubs . This made it easier to flat tow plus on the trail the hubs saved the axles from snapping . I also from time to time used drive flanges instead of locking hubs
  12. Mar 19, 2017 at 4:30 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Credit goes to drr for the link
    When you click on the link scroll down and click on Product Description gives a very well written explanation !!
    Then if there are things you don`t understand you can ask detailed questions
    I thought perhaps someone had designed a kit
    I have never seen these kits nor bought anything from this vendor but if I had a need for rear locking hubs this is a great place to start.
  13. Mar 19, 2017 at 1:00 PM
    InshoreTrekker
    Wyoming09. No link showing to go to.
  14. Mar 19, 2017 at 1:09 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Is your truck 2 or 4 wheel drive, if 2 wheel drive I would just unbolt the universal and tie it out of the way, if it's a 4 wheel drive then that presents a whole new set of problems.
  15. Mar 19, 2017 at 1:18 PM
    InshoreTrekker
    magog45 HEHE thanks for the tip. Already knew about that one but @ 70 my days of climbing under a rig on a regular basis are long gone... Unless you want to come along and help me back up off the ground. I don't know, somewhere along the line my get up off the ground thing went away!
  16. Mar 19, 2017 at 4:07 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not sure what you might be doing wrong it works just fine for me.
  17. Mar 20, 2017 at 11:08 AM
    InshoreTrekker
    Well guys I sold the Tacoma and am looking for something that will work without any changeover hassels. Thanks for the help.
