Locking in 4-wheel drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by Killroy, Feb 18, 2020.
  1. Feb 18, 2020 at 11:30 AM
    Killroy
    Killroy [OP] 1998 SR5 6 cyl Auto 3 Inch lift
    Stedman NC
    1998 SR5 6 cyl Auto 3' lift manual hubs
    I have a 98 Tacoma SR5 I don't mean to sound like a dumbass but how do you lock this thing in.
  2. Feb 18, 2020 at 2:27 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    If you have manual hubs on front wheels turn dial to LOCK
    MT push clutch in and shift the short stick from 2 Hi to 4 Hi
    Shift long stick to 1st gear
    4 Low is for low speeds
    No tight turns or 4 Low on dry pavement.
    Hope this helps
    You'll get better responses by adding your Taco specs to your avatar page
  3. Feb 18, 2020 at 2:28 PM
    eon_blue
    Azusa, CA
    Need to know what kind of 4wd Tacoma you have...manual hubs or ADD? Push button 4wd or J-stick?
    TACO_GUY03 likes this.
  4. Feb 19, 2020 at 9:59 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Don't operate in 4X4 on any hard dry surface at all. It is only for conditions where traction is poor. If you're careful and only move a few feet in 4X4 on hard dry surfaces you probably won't break anything, but if you forget and try to turn you stand a very good chance of breaking expensive stuff. Best to avoid the risk.
  5. Feb 19, 2020 at 10:14 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    FIFY
    These are stout little trucks. You're not going to 'splode your truck if you drive it in 4x4 on pavement. You may increase the wear and tear if you do it often, but you're not going to break anything. But I'm sure someone has a story where they accidentally put it in 4x4 in their driveway and the transfer case fell off, but that's hardly normal.
    @Killroy, there should be a card on your sun visor with instructions.
  6. Feb 19, 2020 at 1:17 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    About the worse thing is the torque bind .
    Worse case you jack up at least one front and one rear wheel to get it out of gear
  7. Feb 19, 2020 at 3:30 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    o_O
    Black DOG Lila likes this.
