Locking point in bed for chain.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Danielnc06, Aug 10, 2016.
  1. Aug 10, 2016 at 5:25 AM
    Danielnc06
    Danielnc06 [OP] Well-Known Member
    NC
    2016 TRD DCLB
    Trying to think of a good place to lock a chain in the bed of the tacoma. Preferably somewhere a torx bit isnt used. I will be locking my mountain bike in the bed and its easy for someone to walk by, see that its simply a torx bit holding all of the drings and come back and snatch it in minutes..
    My first though was to remove the side tiedowns that use two torx bolts, drill out their back plate and use longer torx bolts but use a nylock nut and locktite.. BUT dont tighten it down. Leave it able to spin so it would require two people, one in the bed and one under the bed holding the other side. Make sense?.
    Any thoughts/oppinions?
  2. Aug 10, 2016 at 5:35 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
  3. Aug 10, 2016 at 5:41 AM
    Danielnc06
    NC
    2016 TRD DCLB
    The masterlock has me intrigued but i dont need another lock.. i have one with my chain that i trust more than masterlocks. Im definitely looking into it though. Thanks
    And the part im talking about is a lower tiedown loop with a back plate it has no structural purpose for the bed. Its the only "silver" tiedown in the front of the bed on the sidewalls
  4. Aug 10, 2016 at 7:18 AM
    bryanjoh
    bryanjoh Well-Known Member
    Bryan
    Calgary
    2016 DCLB TRD Sport
    I was struggling with this problem the other day too and just ended up putting a chain through the D rings and the bike frames. I figure there's little to nothing that's entirely thief-proof if they want it bad enough.
  5. Sep 28, 2016 at 8:01 PM
    DrRoboto
    DrRoboto Well-Known Member
    David
    Salt Lake City, UT
    <s>2017 AC Off-Road</s>
    GoFastCamper. OME 886. Medium Dakars. SSO slimline bumper + Warn VR10-S. OGE dual battery system. Mobtown skids.
    Thieves are typically thieves of convenience. The bed bolts are a real doozy to loosen up, and you need to have a T-55 Torx wrench on hand.
    hiPSI, 3GTaco and Lawfarin like this.
  6. Sep 29, 2016 at 5:11 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Yes, mostly if you simply make it a bit more difficult they'll move on to easier prey.
    Stick a BB in the D-ring torx socket and seal it in with RTV to deter anyone from loosening the bolt. I suspect they'd just snip the d-ring though.
  7. Oct 9, 2016 at 1:44 PM
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
  8. Oct 9, 2016 at 5:46 PM
    gpb
    Atlanta
  9. Oct 9, 2016 at 6:42 PM
    crymes
    Cameron
    CT
    2017 TRD OR DCSB QS
    gpb likes this.
  10. Oct 9, 2016 at 7:55 PM
    gpb
    Atlanta
  11. Oct 10, 2016 at 9:36 AM
    Danielnc06
    NC
    2016 TRD DCLB
    I ended up using this master lock anchor and a good kryptonite chain. Thanks for the master lock idea. I positioned it next to the left storage compartment and it looks factory. Thanks
  12. Mar 11, 2018 at 4:44 PM
    EastVanTaco
    EastVanTaco Well-Known Member
    2017 super white Trd Sport DCLB
    Did it go into factory bolts?
    Pics?
    Thanks
  13. Mar 11, 2018 at 4:46 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You can get tamper resistant bolts on Mcmaster.com
    Tacoma2020 likes this.
  14. Mar 11, 2018 at 4:47 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Simple. Fill in the Torx slot with liquid nail.
    remgu2000 likes this.
  15. Mar 11, 2018 at 6:37 PM
    PoppinCorks
    PoppinCorks Well-Known Member
    some butthole tried to steal my kayak out of my bed by unscrewing the d-ring but used a regular screwdriver it looks like. its stripped pretty good so dont think its coming off
    edit- while not the best looking idea... stripping it or filling the head in with some kinda cement could solve that issue. then to have a cut proof chain
  16. Mar 11, 2018 at 9:17 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I simply use the small d rings in the floor with a braided cable and lock. I am never leaving my bike for long. 30 minutes at most. Garage / house or travel to trail.
    Serious thieves will be gone in seconds no matter what. I only worry about the 2 bit thieves.
    hiPSI likes this.
  17. Mar 13, 2018 at 11:19 AM
    EastVanTaco
    How did u mount this.. It can. Only mount to the plastic bed? Not very secure. Im. Having this issue currently
  18. May 5, 2018 at 9:05 PM
    EastVanTaco
    Except its bolted to plastic lol so wtf is the point?
  19. May 5, 2018 at 9:12 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Except the bed isn’t plastic. It’s a fiber glass composite bed. Good luck ripping a nut and bolt through it. You’d have an easier time breaking the actual bolt.
    tonered and EastVanTaco[QUOTED] like this.
  20. May 5, 2018 at 9:15 PM
    EastVanTaco
    well i bought the same lock went home and scratched my head like ...seems way to easy to break out
