Locking point in bed for chain.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Danielnc06, Aug 10, 2016.
  1. Oct 11, 2018 at 4:29 PM
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    Has anybody gotten the master lock to work? I bought one but none of the points match up in my bed.
  2. Oct 11, 2018 at 6:03 PM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Yes, but I've since moved it. I did have to enlarge one of the holes.
    It's now on my driver's side accessory rail.
  3. Oct 12, 2018 at 10:54 AM
    Zack
    Austin, Texas
    That's rad! Sorry to be a pain but would you mind snapping a pic for me? Did you drill into the bed?
  4. Oct 12, 2018 at 1:45 PM
    MCDavis
    RIC, VA
    Here ya go.
    It’s bolted to two sliding accessory rail blocks. Keeps my spare from walking away
    mtskibum16 and EastVanTaco like this.
  5. Oct 12, 2018 at 1:48 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Spare tire spot is under the truck.. why use all you bed space to hold a tire?
    Bowhuntercoop likes this.
  6. Oct 12, 2018 at 1:59 PM
    phsycle
    phsycle Well-Known Member
    CA
    He's got a 6" lift. I'm sure his tires aren't anything close to stock size.
    MCDavis likes this.
  7. Oct 12, 2018 at 2:00 PM
    Dirtridercrf250
    Hahaha damn those underlying facts I didn't know about
  8. Oct 12, 2018 at 2:04 PM
    phsycle
    CA
    For the record, I lock my bikes up to the stock tie down points. I don't want to get crazy with locks, drilling, etc. If they want it bad enough, they will get it. I want minimal damage done to the truck as possible. I will take a cut D-ring vs some numbskull taking an angle grinder to the bed.
  9. Oct 12, 2018 at 2:07 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    I used to lock stuff down to my bed stiffeners. Ended up locking down a cooler and other stuff with a chain and lock.
    Since the bolt has a nut on the inside of the tail light area you wouldnt be able to remove the bolt from the bed stiffeners without removing the tail light and holding down the nut.
  10. Oct 12, 2018 at 4:52 PM
    MCDavis
    RIC, VA
    Bingo. 35/12.5/18.
  11. Oct 12, 2018 at 7:33 PM
    Zack
    Austin, Texas
    That's rad man. Did you fab up the accessory rail tabs or buy them somewhere?
    MCDavis[QUOTED] likes this.
  12. Oct 12, 2018 at 7:51 PM
    EastVanTaco
    EastVanTaco Well-Known Member
    2017 super white Trd Sport DCLB
    Fuk y didnt i think of that lol
  13. Oct 13, 2018 at 1:31 AM
    MCDavis
    RIC, VA
    The rails are factory and are relocated due to the Bakflip cover. I bought the additional blocks off Amazon.
  14. Oct 14, 2018 at 8:59 AM
    EastVanTaco
    You said you had to widen holes or bore something out? Im too lazy to scroll back. What did you have to do exactly?
    I had this lock on my chevy and ford trucks but there was nowhere to mount it on my taco. i saw soneone on TW had drilled 2 holes in his box to install. I decided fuck that.
  15. Oct 14, 2018 at 7:39 PM
    #35
    MCDavis
    RIC, VA
    I removed the factory, silver, tie down from the bedside. You can it's missing below the rail in my picture. The holes almost line up, so I widened one hole on the lock's mounting plate.
    Two weeks later I installed the bedcover and could not access the lock's key hole so I moved the lock to the rail
  16. Dec 10, 2018 at 8:10 PM
    #36
    vsyntax
    vsyntax Well-Known Member
    WNC
    2018 Tacoma TRD PRO
    What cable are you running through the d-rings?
  17. Dec 10, 2018 at 8:22 PM
    #37
    Prjct_Vodo
    Prjct_Vodo Well-Known Member
    Ali
    Michigan
    2019 Voodoo Blue Tacoma TRD Pro
    I have this for my trek bike. Not really that much of an inconvenience once you mount it the first time. Never had an issue with anyone messing with it or trying to steal the bike since it locks shut and fits into the groove of your wheel mount on the bike.
  18. Dec 10, 2018 at 8:29 PM
    #38
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  19. Mar 27, 2020 at 9:18 AM
    #39
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    I have that same Masterlock U-lock, looking to mount it to my bed as well. What specific blocks did you purchase off of Amazon? And does the Masterlock slide along the length of the rails? I'm not sure if I want it sliding back and forth, just want it secure to deter bike thieves.
  20. Jun 12, 2020 at 6:15 PM
    #40
    Dirtjunkie
    Dirtjunkie Well-Known Member
    Northern Colorado.
    2006-Taco-Sport-TRD-Quad Cab-Short Bed, 4x4 No mods to speak of.
    Bump, *ouch*!
    Any other ideas here? I’ve been looking at that Master Lock but have yet to see a decent way of mounting it in a 2006 Taco. The rail mount looks like they could just bend the rail to remove it.
