Locking rear axle swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by DigB, Aug 30, 2010.
  1. Aug 30, 2010 at 2:29 PM
    DigB
    DigB [OP] Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Is it easy or inexpensive to get a rear TRD axle installed in a non TRD Truck? It comes with the ECU and everything.
    I have an 03 Extra Cab and I found a rear axle out of a 2000 4 Runner, would it fit in my truck?
  2. Aug 30, 2010 at 9:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have no idea on the electronics side of the problem but I do know that all the suspension mounts will be different on the 4runner axle. For one, those have coils instead of leafs. So you'd likely have to build spring perches on the axle tube, shackle mounts and front spring mounts on the frame.
    The overall hub to hub width will be similar though likely not identical. 16" stock Tacoma alloy wheels should mount on that axle with no issues, the offset might be slightly different.
    Overall, probably not as difficult as doing an SAS. I am betting that this has been done many times before.
  3. Aug 30, 2010 at 9:27 PM
    DigB
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    well unfortunately that sounds like a little too much work for this guy so I might just go the way of an aftermarket locker like a powertrax no slip and then buy a TRD OR 2nd gen when funds are available!
  4. Aug 31, 2010 at 7:29 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Buy an aftermarket locker instead.
  5. Aug 31, 2010 at 8:36 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't think it would be difficult electrically to integrate, not much to it other than getting power to the acuator/servo to engage/disengage
    via the button you'd have to install but I'd look for a TRD axle approx. to your year truck, FROM a truck not 4runner, but be forewarned, guys are really looking for the TRD Elocker so prices are at a premium, after market may be the way you want to go (ARB setup is great but too pricy for my taste) Auburn, Detroit are options but if you take a little time & keep your eyes open you can find the stock TRD axle, I saw one less than a week ago on Craigs for $ 900.00 OBO, probably gone by now though..... good luck....:cool:
  6. Aug 31, 2010 at 11:32 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I would think that you may be just a well off to just buy a lock rite or a power trax. Probably be alot cheaper and alot less of a headache to install.
    I have rode in a few trucks with this lockers in stalled and they seemed to work very smoothly
