Locking rear Diff.
Discussion in 'Off-Roading & Trails' started by HELIBEAVER, Feb 24, 2011.
  1. Feb 24, 2011 at 9:00 PM
    HELIBEAVER
    HELIBEAVER [OP] New Member
    Texas
    Tacoma
    Im not sure what the Electronic controlled locking rear diff is for, I have a 2011 4x4, Can I use it in conjunction with 4x4 or use it before, then if it doesnt work, use 4x4. Forgive my ignorance, Never had a 4x4 before.
    Thanks for any responses.
  2. Feb 24, 2011 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! You can use the rear diff locker in 4 low range.
  3. Feb 24, 2011 at 10:45 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The locker is generally used in offroad situations when you think you might get stuck or are stuck. You also could use it on slippery boat ramps, and those types of situations.
    It'll only work in 4lo range.
  4. Mar 1, 2013 at 8:36 PM
    ChanhDoan
    ChanhDoan Member
    C DOAN
    TEMPE, AZ.USA
    2001 Tacoma SR5 PreRunner, 98 4Runner, XD
    PLANNING lift 4" on 15LT tires, but only 2WD with TRD rear diff lock, THEN ?? worth or not?
    How is exactky when I need to put the button to engage the rear diff lock? in the manual book only say when you get STUCK in the sand and get out from there and return to normal but..how is the road with mud and hard to go with 2wd?? Can I use in that situation and truck TRD Sport...(do not have locker, of course) but LSD work instead and AUTO or what?? to confuse about 2WD of road, some expert please help and please excuse for my English, Thank you very much (cam on rat nhieu...VIET)
  5. Mar 2, 2013 at 5:56 AM
    Janster
    Jandy
    Lancaster, PA
    Pardon my response, as I'm a little confused of what you're asking.
    You list that you own a 2001. And I'm not sure 'what' truck you are referring to.
    If you have a TRD Off-road version (Pre-runner or 4WD variety) ....
    Utilize in this order on non-pavement (hard non-slip surfaces) only:
    If you can't drive the terrain in 2WD - Go into 4WD.
    If you can't drive the terrain in 4WD - Go into 4Lo range.
    If you can't drive the terrain in 4Lo range - engage the locker.
    Note #1: The locker will only engage in 4Lo range on a 4WD vehicle
    Note #2: The locker will engage on a 2WD Prerunner
    1995-2004 trucks do not have TRD Sport and they do not have AUTO LSD.
    Some (rare) 1995-2004 may have a mechanical LSD
    2005-2008 TRD Sport has mechanical LSD. Only SOME have AUTO LSD but they DO NOT have mechanical LSD and AUTO LSD on the same vehicle.
    2009+ ALL trucks have AUTO LSD
    2009+ TRD Sport DO NOT have mechanical LSD
  6. Apr 24, 2013 at 6:47 PM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    As long as we're on the topic, what would be the advantage of doing the 2wd hi locker mod? Seems like locking up in two or four high is just asking to tear shit up in the differential.
