locking rear differential install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRUCK JENSEN, May 6, 2014.
  1. May 6, 2014 at 12:57 PM
    TRUCK JENSEN
    TRUCK JENSEN [OP] Member
    TRUCK
    JENSEN BEACH, FL
    2014 PRERUNNER
    I am getting a 2014 Double cab, v6, 4x2, prerunner this week and with towpackage. I am saving about $5-6000 by not getting the trd off road package. I had a trd off road with locking rear differential that worked great when i needed it at the boat ramp. I am thinking now i need the rear locking diff and hope you guys/gals can help. Can i install the same locking rear end in the non trd? and is it a matter of just wireing or do I have to modify the rear end. Thanks
  2. May 6, 2014 at 1:01 PM
    TCprerunner
    TCprerunner Well-Known Member
    Its a different rear end. You would have to swap out for the e locker rear end... Better off just getting a arb air ocker and doing it right. Honestly there is no need for a locker on a boat ramp.
  3. May 6, 2014 at 1:03 PM
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    To use the Toyota e-locker, you will need to swap the entire axle, not just the third member. 8.4" SR5 rear end vs 8" TRD Offroad ring gear isn't compatible. Then you'd have to wire it up. Or you could go with an aftermarket like ARB, which has a great reputation.
  4. May 6, 2014 at 1:04 PM
    BudMan
    Bret
    06 TRD Sport DC 4x4
    stuff
    TC, you beat me to it!
  5. May 6, 2014 at 1:05 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Get a 4x4.
  6. May 6, 2014 at 4:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yellow wire mod, look it up.
    But really do yourself a favor.... get a 4x4 with the OR package, you will thank yourself
  7. May 6, 2014 at 7:36 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    If you insist on the 2wd I would second the arb suggestion if you want a locked rear.
  8. May 6, 2014 at 8:13 PM
    TCprerunner
    What does the yellow wire mod have to do with his pretunner? And why would a boat ramp warrent a 4x4 off road?
    Don't get me wrong 4x4 is awesome I have another vehical for that.. But my prerunner is plenty capable in most situations.
  9. May 6, 2014 at 8:33 PM
    bueller
    bueller Well-Known Member
    AZ
    Obviously you've never been on a steep slippery boat ramp in a two wheel drive. I've seen loads of people get pulled out at the ramp because they had no traction.
  10. May 6, 2014 at 9:09 PM
    TCprerunner
    Out of every lake i have been to in Texas (And thats more then i can count including Some on the public grasslands that only see maintenance ones a year) I Have never seen a boat ramp that was not graded and at a steep grade... Guess the core of engineers around here is smarter..
  11. May 6, 2014 at 9:21 PM
    TCprerunner
    Yeah i honestly have never been on a boat ramp outside of texas and Oklahoma... I forget there are hills in other places :D
    And on the ARB Comment cant you get one set up for under $1500? Honestly never priced one after seeing the cost of just the locker its self.. I Personally would go for a Lock rite... But i also don't have to worry about ice or snow often here..
    Everything i deal with is about the same in florida though.. Didnt really think steep ramps would be a problem. Guess im ignorant with the topic
  12. May 6, 2014 at 9:25 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    about 1000-1200 for the arb
    then the compressor and fitting (not sure if it comes with it)
    then installation which could run 200-350
    These are mere guesses but I think they do run sorta correct
  13. May 6, 2014 at 10:10 PM
    TCprerunner
    Yeah that's why my bronco is just welded lol
  14. May 6, 2014 at 10:20 PM
    TCprerunner
    We don't get snow much so not a issue and its not a daily. Only used for camping trips and hunting. Most roads its on are dirt but not really that bad on pavement. The swampers are the worst part lol
  15. May 6, 2014 at 10:36 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I have had it happen also. That was what drove me purchasing my Tacoma. I was stuck on the ramp with my 2x4 and boat trailer and they were opening the gates on the dam. I had swiftly rising water up to the door and covering most of the bed when someone pulled me out. The concrete was too slippery to get traction with an open differential. Another 10 minutes and the truck would have been submerged.
  16. May 6, 2014 at 11:00 PM
    TxFireman
    San Antonio, Texas
    Yes, they're pricey, but when you compare to the cost of getting another rear with a factory locker ... or the cost of a 4x4 (for someone who will seldom use it) it's probably the better option. Personally I can't imagine not getting 4wd.. but that's me.
  17. May 6, 2014 at 11:03 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    posted in wrong thread, oops!
  18. May 6, 2014 at 11:16 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    A cheaper option would be to get a truetrac. It will install in your current diff, and is almost just like a locker. If you never offroad it would be a great option for you IMO. I offroad, and I still love mine
  19. May 7, 2014 at 6:56 AM
    TRUCK JENSEN
    TRUCK
    JENSEN BEACH, FL
    2014 PRERUNNER
    Thank you, excellent debate and informaton. I have seen others spin and guys had to jump on the back of the truck to get traction... tires SMOKING! My ramp is pretty good but there have been times i had to lock in the rear on the TRD. Anyway I guess I will see what happens and I think $1500 is better than the $5000 extra I would be paying for the TRD.
    Oh by the way I did actually purchase a GMC $10,000 more and brought it back. The steering and the response of the gas pedal I just couldnt get used to. The Toyota has tight steering, a very responsive Gas pedal and resale is unbelievable So It is good to be back with a Tacoma. Thanks for all your help again and I will let you know how I do.
  20. May 7, 2014 at 7:15 AM
    smmarine
    Melbourne FL
    I would also look into a Detroit Truetrac. It's a gear driven LSD. I love mine, can't believe how well it works. For what you're doing I think it would be a great option. It's always there when you need it, never have to worry about it not engaging via electrical or air problems, and it will be a lot cheaper. Unless you offroad a lot and lift a tire you won't have a traction problem. Even when I lift a tire I can just lock the ebrake and i pull right out
