Locking Tailgate recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011 Dbl LB, Jul 31, 2021.
  1. Jul 31, 2021 at 6:32 AM
    2011 Dbl LB
    2011 Dbl LB [OP] Member
    2011 Tacoma Prerunner TRD Dbl Cab Longbed
    Before I install an MX4, or other folding tonneau cover, on my 2011 Tacoma Prerunner long bed TRD Sport I need to get a locking tailgate. Looking for recommendations. Thanks
  2. Jul 31, 2021 at 7:16 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    As an affordable option, you could put a hasp and padlock on the inside.
  3. Jul 31, 2021 at 4:45 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    I bought a Pop & Lock PL5400 for mine. It's the manual version that uses your Taco key. Went on pretty much per instructions except that I couldn't see any way to get it inserted thru the tailgate opening without removing the metal plate that turns when you pull the handle. Came off easily tho, just had to put the spring back in place when reinstalling (do look at where it engages before removal). Easy job.
    They also have a model with a solenoid that connects to the factory lock/unlock signal for the passenger doors. You can also add that functionality later to the manual version if you wish.
    tacoman45 and 2011 Dbl LB[OP] like this.
  4. Jul 31, 2021 at 11:50 PM
    2011 Dbl LB
    Thanks very much
  5. Aug 1, 2021 at 1:42 AM
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    After weeks of researching I’ve found this is the best method
    JGO and winkel[QUOTED] like this.
  6. Aug 1, 2021 at 1:45 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  7. Aug 1, 2021 at 1:57 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I have the 5400 as well, and it could be just mine, but the handle is super stiff which makes me feel like I going to break the latch every time I open the tailgate. That said it’s lasted 2 years fine.
    Plus I’m too lazy to lock it every time manually lol.
    It works, but wasn’t up o my satisfaction so I’ll be going back to OEM and gonna try the model that wires to the power door locks.
  8. Aug 1, 2021 at 4:34 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Pace edwards make a great lock that you can lock and unlock with your key fob
  9. Oct 16, 2022 at 9:04 PM
    guest_707
    guest_707 Well-Known Member
    I was doing some research for someone who has a 2nd gen. I installed the oem power lock tailgate for my 3rd gen but at no point did I find any info on oem power locking tailgates for the 2nd gen. Did they really never come with the option or am I tripping?
  10. Oct 17, 2022 at 11:26 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    PL5400 if you want a physical key. PL8521 for electric actuator version only.
    Pace Edwards does have an option but it's a little more complicated for no realized benefit (IMO). Other options on the market are generally inferior to the P&L and Pace Edwards (again IMO).
    2nd gen never came with an OEM locking option. All locks for our tailgates are aftermarket.
  11. Oct 17, 2022 at 11:28 AM
    trail_limo_project_
    trail_limo_project_ Active Member
    Ren
    Oahu, HI
    1999 Pre-Runner & 2018 TRD Off-Road DCLB
    I went with the OEM power tailgate lock. Easy install works well with your fob.
  12. Oct 17, 2022 at 12:46 PM
    wi_taco
    Adam
    SE Wisconsin
    You have a 3rd gen, this is 2nd gen forum. No OEM 2nd gen options.
  13. Oct 17, 2022 at 12:59 PM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    The reason I went with pace edwards is that ive read numbers posts about how p&l has failed on them. Im going on two years now with no issues. I also like that i can just unlock driver door with one press and two to unlock tailgate.
  14. Oct 17, 2022 at 5:20 PM
    trail_limo_project_
    Ren
    Oahu, HI
    Sorry sorry, my mistake. Didn't see that >.<
  15. Oct 17, 2022 at 7:47 PM
    dmanars
    dmanars Well-Known Member
    I went manual pop and lock, after a year I upgraded it to power lock. I also have a adjustable stainless steal clamp. Figured that would be enough
    the power lock isnt hard to install, but it does take some time and a little swearing...
    The manual lock is really easy to install. Really pleased with he setup, and have had it manual lock for 7 years.
    The handles do fad pretty fast, I would advise you to paint it first.
    I ended up using truck bed liner when I installed the power lock.
