Locking tailgate (that's better quality than Pop and Lock)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddy, Feb 6, 2020.
  1. Aug 21, 2020 at 11:49 AM
    #61
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Did get a response from Ed and got tracking info. Will post back my results later after it arrives.
    Update 6/6/21: 100% do not recommend DynoProducts/DynoLock due to a flawed design and terrible customer service. Write up coming sometime in future. Avoid using this product!
    Update 3/15/22:
    Finally wrote up a full product review, click here to see it. Apparently this company no longer exists and the scumbags stole my $140 for faulty products.
    jproffer likes this.
  2. Aug 24, 2020 at 10:48 AM
    #62
    jbohar47
    jbohar47 Member
    2015 Tacoma TRD Sport 6 speed
    Just ordered a Pace Edwards PowerGate lock. Saw they were going out of stock so I pulled the trigger. Hopefully next week I can comment on it. Any install pro tips?
  3. Aug 24, 2020 at 9:40 PM
    #63
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    No advice specific to the PE model. Generally, the hardest part, by far, is running the wiring. I followed the original wiring harness that goes forward from that area.
    Went through the plastic things on the bottom of the passenger side of the tailgate (had to drill holes/slots for the new wire). They come out pretty easy..when you see it, you'll get it.
    From there, I went across near the bumper then forward along the driver's side. There's a grommet right under the front driver's door. I didn't even pop it out, I just poked a hanger or something through it and stuck the wire up. It comes out just barely under the seat, JUST inboard of the plastic cover you have to take off anyway to the left of the seat. Reach under the carpet about center of the seat...you'll find your wire. Wires are blue/red and blue/black. I tapped mine backwards (lock was unlock, unlock was lock), so I just switched 'em at the tailgate.
    Let us know how it went and what you think of the brand.
    jbohar47 likes this.
  4. Aug 25, 2020 at 9:35 PM
    #64
    wi_taco
    Adam
    SE Wisconsin
    FYI - Just received the "HD" unit from Dyno Products. I'm no rocket surgeon but that sure looks like it says POP Locks...
    Update 3/15/22:
  5. Aug 26, 2020 at 5:29 AM
    #65
    jproffer
    Jim
    Perryville, MO
    Mmmhmmm...funny isn't it. That pin that comes out of the block is what I couldn't figure a way to align. I do have an aftermarket handle, but I didn't think it'd be THAT different. Let me know how it goes....hope you have better luck than I did :)
  6. Aug 26, 2020 at 6:51 AM
    #66
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    Great thread, that Pace Edwards looks solid. Be curious to see another review.. Too bad they don't make a nice handle as well with a keyed lock to go with it. I still have my stock handle but I don't have faith in going with a Pop n Lock either.
  7. Aug 26, 2020 at 7:39 AM
    #67
    jproffer
    Jim
    Perryville, MO
    I had the manual key lock P&L. Within a couple years, it was fading and sticking. Even when I cleaned it and lubed it up good, it didn't feel as good as I thought it should. It worried me enough that I figured sooner or later, it'd leave me locked out of my bed (I have a cover too, so zero access without the tailgate opening), so I got the electric. Took out the key lock altogether and did the paracord mod, just in case.
  8. Aug 26, 2020 at 8:04 AM
    #68
    GRNT4R
    NC - Triad
    TBD
    Sounds good, I think this Pace Edwards with the cord trick is the way to go. Thanks, I can keep my camera and OEM handle
  9. Aug 26, 2020 at 8:14 AM
    #69
    jproffer
    Jim
    Perryville, MO
    The P&L manual locking handle has the hole for the camera......but still....not great quality.
  10. Aug 26, 2020 at 8:15 AM
    #70
    GRNT4R
    NC - Triad
    TBD
    Yeah, every thread I have read pretty much has the majority saying the quality doesn't make the cut. Sticking with the OEM handle camera combo is fine with the Pace Edwards actuator and lock
    jproffer[QUOTED] likes this.
  11. Aug 26, 2020 at 8:17 AM
    #71
    jproffer
    Jim
    Perryville, MO
    Gotcha...just didn't want the camera or lack of being your only deciding factor....especially when it's not even a factor. I'm with ya on skipping the P&L handle :thumbsup:
  12. Aug 26, 2020 at 8:19 AM
    #72
    GRNT4R
    NC - Triad
    TBD
    Agreed, since I already have the factory camera and the handle is made decent, im thinking the PE is the way to go for the sturdiness. That backing plate looks solid and adding some cord isn't that bad. can even get black cord to make it less visible if it was that big of a deal
  13. Aug 26, 2020 at 9:20 AM
    #73
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
  14. Aug 26, 2020 at 10:47 AM
    #74
    jproffer
    Jim
    Perryville, MO
    Nice. Looks well made, and plug-n-play....not that tapping these particular wires is that big of a deal, but some people are leary about shit like that, so this gives an option.
  15. Aug 26, 2020 at 11:50 AM
    #75
    GRNT4R
    NC - Triad
    TBD
    That does look like a good option. How bad was the install and do you feel its solid and sturdy? Looks like for 2nd gen you have to do some drilling for it to mount to the tailgate since there is not Bolt n Lock rod make yet.
  16. Aug 26, 2020 at 12:03 PM
    #76
    MrFixit420
    MrFixit420 Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    I'm very happy with mine. It was easy to install, like everyone says the hardest part is running the wiring under the truck. Just take your time and secure it along the way so it doesn't rub or get in the way.
    Good luck.
  17. Aug 26, 2020 at 12:05 PM
    #77
    GRNT4R
    NC - Triad
    TBD
    Did your PE model come with a plug n play option? Im surprised they haven't made one yet since I don't see it on the website unless they don't have it shown.
  18. Aug 26, 2020 at 12:14 PM
    #78
    bacollier90
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Very straightforward. I ran it to the passenger door to keep the ability to unlock just the driver door. The harness was perfect and I got the special plug so no cutting or splicing. Only thing I definitely would have done different, and still may do, is to install some dynamat or similar because the lock is loud inside the hollow tailgate.
  19. Aug 26, 2020 at 12:19 PM
    #79
    GRNT4R
    NC - Triad
    TBD
    Nice info, that dynamat makes since. Maybe they will come up with whatever they need for the 2010's to make it a simple install. Running it to the passenger door makes since. So to unlock it, you unlock all doors and then the tailgate unlocks. Clever.
    bacollier90[QUOTED] likes this.
  20. Aug 26, 2020 at 1:33 PM
    #80
    MrFixit420
    Portland Oregon
    They call it plug and play but you have to install 2 taps on the control wires. Simple and easy to do. No drilling required and the taps only require a pair of pliers to install.
