Locking the rear axle down; Axle wrap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Mar 15, 2019 at 5:59 AM.
  1. Mar 15, 2019 at 5:59 AM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2011 White Tacoma Prerunner SR5 | V6 | Auto
    Dakar leafs & nitrochargers, running boards, ditch lights
    So originally what I had the dakars installed the rear became super stiff and all axle wrap was instantly fixed. It was great, it was a pretty stiff ride but I didn't care.
    :burnrubber:
    So as time went on, I presume the springs broke in? They became a bit softer, but this also allowed for axle wrap to creep back in...
    :facepalm:
    So my question is if I get the additional AAL to turn the pack into the heavy duty pack and remove one of the overloads, would that lock down the rear axle and stop the last bit of wrap?
    :locked:
    Also, does anyone have experience doing this, specifically I'm not trying to add any more height to the back so that's why I'm wondering if removing one of the overloads will counteract adding another leaf.
  2. Mar 15, 2019 at 6:09 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Traction bars are the only solution to axle wrap that I know of for our trucks. I think regardless of what you do with the rear leafs, once the leafs settle and metal relaxes, the axle wrap will return.
    jross20 [OP] likes this.
  3. Mar 15, 2019 at 6:09 AM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    2005 tacoma
    I bet with doing that it will add height still. One thing I did on a 89 3.4swap with a sc set up I built was took some cheapo overload springs from autozone the 1/2 leaf style and mounted it on the forward side of the spring pack it fixed the axle wrap right up. Might be worth trying I think I had $35 into it.
    Bobcdn, jross20 [OP] and Biscuits like this.
  4. Mar 15, 2019 at 6:12 AM
    Biscuits
    Huh. That's an idea.
  5. Mar 15, 2019 at 6:18 AM
    cfcarpenter
    Clint
    2005 tacoma
    It was something I saw on a forum at some point. Pretty cheap way to try. Didn’t want a set of trac bars hanging down.
  6. Mar 15, 2019 at 6:20 AM
    Biscuits
    I don't either, so I've learned to live with the axle wrap. That said, it can be pretty damn annoying.
  7. Mar 15, 2019 at 6:26 AM
    jross20
    Georgia
    I think because it's really early in the morning I'm having a hard time visualizing that, do you have a photo?
    cfcarpenter likes this.
  8. Mar 15, 2019 at 6:28 AM
    cfcarpenter
    Clint
    2005 tacoma
    I lied now that I see the picture, it was on my 1st gen it’s all coming back to me. I had a lot of axle wrap with the camper setup.
  9. Mar 15, 2019 at 6:32 AM
    Biscuits
    Torspd likes this.
  10. Mar 15, 2019 at 6:37 AM
    jross20
    Georgia
    Is that a leaf spring helper?
  11. Mar 15, 2019 at 6:58 AM
    cfcarpenter
    Clint
    2005 tacoma
    Sure haha I’m not sure what it’s called but that sounds right
  12. Mar 15, 2019 at 7:04 AM
    jross20
    Georgia
    Do you happen to know what brand it was or where you got it from?
  13. Mar 15, 2019 at 7:07 AM
    Wulf
    Wulf null
    Jake
    Denver
    amocaT 69
    Trail damage
    You only really need one and depending on the design you may not lose any clearance at all:
  14. Mar 15, 2019 at 7:07 AM
    cfcarpenter
    Clint
    2005 tacoma
    I think autozone. Mine are just sitting in a box in the shop but I’m sure at the cost of shipping you could just buy a set.
  15. Mar 15, 2019 at 9:48 AM
    jross20
    Georgia
    Okay I'll give AutoZone a look!
    Thanks!
  16. Mar 15, 2019 at 7:54 PM
    cfcarpenter
    Clint
    2005 tacoma
    Let me know if it works!
  17. Mar 15, 2019 at 8:02 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    I thought that correcting the driveline angles fixed axle wrap?
  18. Mar 16, 2019 at 6:30 AM
    jross20
    Georgia
    Drove line angles don't help if the rear axle can't hold it's liquor.
    Although I still think it would help if if had a double cardan.
    QuicksandTaco likes this.
  19. Mar 16, 2019 at 7:45 AM
    Bobcdn
    Bobcdn Well-Known Member
    WTB; 2nd gen well built Tacoma
    I think it needs both the rear leaf springs addressed as well as the dual carton joint. That 'helper spring' idea is worth considering.
  20. Mar 16, 2019 at 7:20 PM
    jross20
    Georgia
    Yeah I've been looking into it, I looked at one of those traction bars but good Lord that looks like a lot of work and cash. Cash that can be spent on buying the future 4x4 4runner
