lockout hubs to reduce drag?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustball, Jan 18, 2012.
  1. Jan 18, 2012 at 11:21 AM
    dustball
    dustball [OP] Active Member
    Can anyone educate a non mechanical city kid with this question? have a 4x4 access cab and have heard folks say that even when in 2wd mode there is still added engine drag because of the 4wd mechanism. One co-worker with 1rst generation taco re-did his and installed lock out hubs, claims it reduces wear & tear on 4wd parts?
    can anyone explain this? pros-cons. etc?
  2. Jan 18, 2012 at 11:24 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    as far as I know the only way to get manual hubs on a 2nd gen is to swap in a solid front axle which isn't very practical.
    Your buddy is right though, manual hubs reduce drag by disconnecting the front diff from the wheels.
  3. Jan 18, 2012 at 11:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I do not believe there is a way to put manual hubs on a 2nd Gen. There is some truth to what your friend is saying, just not enough to where it's worth tearing apart the entire front end to save a tiny bit of fuel economy.
  4. Jan 18, 2012 at 11:29 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    there are more advantages to manual hubs though, including the ability to drive in 2wd low range (good for backing up trailers if you have a manual transmission).
    still not worth completely re-doing the entire front end though. Your buddies first gen only required a different set of spindles and CV shafts to convert it.
  5. Jan 18, 2012 at 11:59 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Advantages or no, has anyone even retrofitted a 2nd gen?
    And yeah, it would never pencil out just for MPGs.
  6. Jan 18, 2012 at 12:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah I haven't ever seen manual hubs on an IFS 2nd gen.
  7. Feb 20, 2012 at 1:35 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Are there any companies that make a kit or parts to change out I had a mile marker kit for my jeep for hubs. I want the hubs so my did bearings last and I can run a high angle on the hwy
  8. Feb 20, 2012 at 2:46 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Nope
  9. Feb 20, 2012 at 5:21 PM
    Toyo_Jet
    Toyo_Jet Well-Known Member
    Shane
    Flatlands of Indiana
    10 4X4 V6 SR5 access Cab
    On the older 4wd trucks, the lockout hubs disconnected the axles so that you didn't backdrive the front prop-shaft when in 2wd. A lot of extra rotating machinery that was not needed. Your 2nd gen has an axle disconnect in the front diff so that you don't backdrive the prop shaft. It may not be as free wheeling as the old hubs, but I don't think you'd gain much with lockouts at the hubs.
  10. Feb 20, 2012 at 6:04 PM
    lowinhz
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    I know that it unlocks in the front diff I want something to unlock at the hub. From what I hear about the bearings in the diff they are a pita to replace I want my cv's not to spin on either side of my diff.
  11. Feb 20, 2012 at 8:22 PM
    badger
    badger Well-Known Member
    07 SR5
    This is correct, but there is more. In a conventional full time system the pinion and the ring gear are driven as well. With the ADD only one shaft and the spider gears are driven. The savings in fuel by eliminating this small drag is nil. As for the bearings, they are under no load, so the wear is again nil. There even be an advantage to having some of the parts rotating in the diff to move lubricant around.
    In addition, some models that do have conversions available end up with weaker components in the bargain. Personally, I would prefer manual hubs if a well engineered kit were offered.
  12. Feb 20, 2012 at 8:37 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Ya I wish someone made a kit for manual hubs also, if they did i wouldn't have to worry about my front cv shaft/ bearing vib. It was fixed under warranty, but if it dose it again out of warranty i'll sell it.
    Brett
  13. Feb 20, 2012 at 11:51 PM
    badger
    07 SR5
    How did they fix it under warrantee? I didn't think there was a fix except the ECGS bushing. You cound install an ARB too. :)
