Lockright installation on 8.4" non TRD rear
Discussion in 'Technical Chat' started by Yoytoda, Aug 16, 2011.
  1. Aug 16, 2011 at 4:02 PM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I was wondering who on here has done the install. I have heard mixed messages on what needs to be done on Toyota thirds to install the lockright. It seems as though the 8.4" does not need the carrier removed from the third and the ring gear does not need to be removed.
    Can anyone confirm this???
    I read this from Chase at East Coast Gear supply
    "As far as installation goes. Some vehicles require the ring gear to be removed from the carrier in order to drop the crosshaft out. On vehicles with side adjusters 14 bolt, chrysler rearends, and toyota 3rds, not 8.4 The backlash will need to be reset to the factory specifications."
  2. Aug 16, 2011 at 4:07 PM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    i just recently put one in mine and i had to take the ring gear off to get the cross shaft out. there was no way around it.
    are you thinking of putting one in?
  3. Aug 16, 2011 at 4:13 PM
    Yoytoda
    Roland
    completely stock
    yep im going to... just weird that chase said no backlash required but maybe its because the 8.4" doesnt have side adjusters? :notsure:
    install seems pretty easy and straight forward.
    What keeps the retaining pin in there?
  4. Aug 16, 2011 at 4:19 PM
    TanSR5x4
    William
    Houston TX
    00 Tacoma SR5 4x4
    idk i did it and just forgot all the fine details. so yeah its pretty easy lol you shouldnt have any problems
    this is the thread i started
    http://www.tacomaworld.com/forum/1st-gen-tacomas/165566-lock-right-install.html
    its got a couple good links and write ups i followed to get me through it
    although its mostly just me freaking out thinking i screwed something up lmao
  5. Aug 16, 2011 at 4:39 PM
    Yoytoda
    Roland
    completely stock
    how do you like it so far?
    Im not too afraid of the install no big deal... just gotta keep track of everything and make sure i dont do anything to throw the backlash off
  6. Aug 16, 2011 at 4:42 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    is the 1st gen have the 8.4in axle or the 8in that comes in the offroad in the 2nd gen?
  7. Aug 16, 2011 at 4:43 PM
    Yoytoda
    Roland
    completely stock
    i only know that second gens are 8.4" except the TRD offroad is 8"
  8. Aug 16, 2011 at 4:54 PM
    hard2kill
    Rhinebeck NY
    tansr5x4 is talking about installing it in his first gen...just chking cause his install may be different
  9. Aug 16, 2011 at 5:36 PM
    TanSR5x4
    William
    Houston TX
    00 Tacoma SR5 4x4
    oh yeah i didnt even realize. i just saw 8.4" and thats where my expertise is lol
    i love it. im always really careful on tight corners and rights at red kinda suck. and i find myself getting sideways here and there but only cuz i want to. its great off road but i did get stuck on the first thing i tried
    but i dont think it was the lockers fault
    its my friends dried up pond and it was super soupy mud
  10. Aug 16, 2011 at 6:05 PM
    Yoytoda
    Roland
    completely stock
    also gear ratios effect the thickness of the ring gear. i guess ill find out when i pull it out...
    some vehicles do not require removing the ring gear just keeping my fingers crossed that the 4.10s are one of them. but not with my luck...
  11. Aug 18, 2011 at 7:28 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Nope, most likely you will have to remove it. I had to remove it on my 4.10's (1gen truck with same rear diff)
    So I am pretty sure you will have to too. Just mark everything so it goes in the same position as before and you will be fine..
  12. Aug 18, 2011 at 10:23 AM
    Yoytoda
    Roland
    completely stock
    Yup it's already done. Only thing I may have screwed up is I think I'm one or two teeth off when putting the R&P together. My mark got smudged off somehow. It doesn't make any noise and seems fine. Fingers crossed.
    Took about 5 hours only because I had to make a jig to hold the diff while I took the ring bolts out.
  13. Aug 18, 2011 at 10:30 AM
    BlueT
    NorthEast
    Did you put grease on lock-right teethes ? Loctite on ring bolts?
  14. Aug 18, 2011 at 10:57 AM
    Yoytoda
    Roland
    completely stock
    yup used the max lock red locktight on the ring bolts and the bearing case bolts and used grease on the lockright teeth but it seems the grease wore out becasue the more i drive it the less smooth it is... oh well, not my dd so i dont really care.
