Lockrite Install
Discussion in 'Technical Chat' started by rmb_crew, Nov 16, 2010.
  1. Nov 16, 2010 at 11:46 AM
    rmb_crew
    rmb_crew [OP] My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    I ordered a lockrite locker for my tacoma and would like to start looking at what the install involves before i get started. Has anyone done it? Tips? Tricks? A How-To or anything?
  2. Nov 16, 2010 at 11:52 AM
    Di Trut
    Di Trut Well-Known Member
    did you bother to google it? it's been done a million times. 4x4wire has a decent write up..
  3. Nov 16, 2010 at 11:55 AM
    rmb_crew
    Yes I googled it, I searched here and ttora. It has been done many times. I just can't find any 05+ write ups.
  4. Nov 16, 2010 at 12:03 PM
    Di Trut
    05+ have the same rear end as the older tacomas, so any of those writeups will be what you need.
    when i did mine the instructions that came with were pretty clear.
    only tip i have is if you have to remove the ring gear, make sure to mark it so it goes back on in the exact same place. and heat it up in the oven to re-install.
  5. Nov 16, 2010 at 12:05 PM
    rmb_crew
    Oh ok. I didn't know it was that simple.
  6. Nov 16, 2010 at 1:39 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Its very easy, like somebody else said mark everything.... before disassembling. The only fishy part in instructions is the direction of the spacer. Also make sure when you putting back to locktite every bolt. :)
  7. Nov 16, 2010 at 1:40 PM
    rmb_crew
    That was one of the things i didnt understand, that and putting it back together and setting the backlash?
  8. Nov 16, 2010 at 1:44 PM
    BlueT
    NorthEast
    When I get home I will try to dig up my pictures from the install. There is no need to set backlash unless you made major screw up (like forgot to mark your ring against the carrier ) Althoguh I would check anyway since diff is out you may as well check all of it, anyway. ;)
  9. Nov 16, 2010 at 1:45 PM
    rmb_crew
    ok cool. thanks for the info
