Locks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kk7411, Nov 28, 2015.
  1. Nov 28, 2015 at 9:00 AM
    kk7411
    kk7411 [OP] Well-Known Member
    White 2008 Tacoma TRD 4x4
    How can u turn on auto lock when u turn the off
  2. Nov 28, 2015 at 9:00 AM
    Large
    Large Red
  3. Nov 28, 2015 at 9:02 AM
    kk7411
    When u turn the key off how can u turn on the auto lock
  4. Nov 28, 2015 at 9:11 AM
    Pigpen
    Dan
    Northwest Montana
    Are you trying to lock yourself in?
  5. Nov 28, 2015 at 9:13 AM
    kk7411
    Lol no I'm trying when I turn the key off shut and the door automatic lock
  6. Nov 28, 2015 at 10:43 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You can't. That is not an available option on these trucks.
