Loco's "Brack Burrito Build" BS Thread...with some build...mostly BS.
Discussion in 'Other Builds' started by loco, Jun 4, 2015.
  1. Aug 12, 2015 at 4:22 PM
    #2041
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Step 1
    Give the lady your seed at the tire shop
    Step 2
    Use saved monies for trans
    Step 3
    Fix the next thing that breaks
  2. Aug 12, 2015 at 4:41 PM
    #2042
    loco
    loco [OP] Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    I'm not quitting yet... It could possibly be that the TV Cable came disconnected at the trans side. I'm not willing to throw in the towel yet but I would really like to avoid an expensive tow home from work...
  3. Aug 12, 2015 at 4:43 PM
    #2043
    loco
    Phil
    Virginia Beach, VA
    Also for you uniformed folks... TV is Throttle Valve for the Transmission... it's what holds the gear when you bring up the RPMs. If it's stuck or disconnected it makes big problems like I have now. If I can't wrap it up over the next two days I'll have it towed home and drop the pan so I can dig into the transmission inners.
  4. Aug 12, 2015 at 4:46 PM
    #2044
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Must of those folks moved on to the 3rd gen threads... :spy:
    2ndGenJonny likes this.
  5. Aug 12, 2015 at 4:47 PM
    #2045
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    My dad just had to replace his trans in his '97 F350. Shit's expensive. Now yesterday he smelt diesel, got out and it was just puking out so he's got another shitty fuel fuel "leak" problem. He said you could see a trail as he drove...........
  6. Aug 12, 2015 at 4:48 PM
    #2046
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I'm still here, and still clueless with transmissions. :wave:
    Sefferston likes this.
  7. Aug 12, 2015 at 4:49 PM
    #2047
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I am one of those uninformed people.
    I will go sit quietly in the corner now.:pout:
  8. Aug 12, 2015 at 4:54 PM
    #2048
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    See what happens when you switch from a manual!!!
    Jk man, bummer to hear that. Hopefully it's not a new transmission fix :/
  9. Aug 12, 2015 at 4:56 PM
    #2049
    SACTOWN
    Greg
    :wave: I am glad... At least someone still wants to learn..... :spy: @loco.... Get the balls and do it in the parking lot at work... Sure they won't mind you doing it on your lunch break...
  10. Aug 12, 2015 at 5:11 PM
    #2050
    loco
    Phil
    Virginia Beach, VA
    The base I am on currently has a "No Maintenance Policy"... battery died??? Tow Truck. Flat tire??? Tow Truck.
    I went back after most people left this afternoon and kind of slid under there using the FRS as a screen. Popped the hood only when necessary and then right back down to not let on that I was working on it. Dropping that pan at work isn't going to happen but I would try and swap this TV Cable if I need to all sneaky like...
  11. Aug 12, 2015 at 5:16 PM
    #2051
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Did you know 37x12.5x16.5 military are really cheap and it would be line 600 bucks to get them and then the op would be finally rolling on the right tires for the stuck and then there would be n kissing the old ladys ass
    SACTOWN likes this.
  12. Aug 12, 2015 at 5:20 PM
    #2052
    SACTOWN
    Greg
    That's right forgot you work on a base... That sucks.... Sign up for AAA... Haahaahaa you might need it...
  13. Aug 12, 2015 at 5:28 PM
    #2053
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Drive off the base in first (or reverse) then set up shop on the road side or nearest McDonald's.
  14. Aug 12, 2015 at 5:33 PM
    #2054
    loco
    Phil
    Virginia Beach, VA
    Hahahaha we shall see. I'll keep with it over the next few days and then have it towed over the weekend if necessary so I can get a ride up there or whatever.
  15. Aug 12, 2015 at 5:47 PM
    #2055
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    This thread is starting to be like WEAF (WasExpoAsFuck)!
    dakotasyota, alee891, DCLBFTW and 2 others like this.
  16. Aug 12, 2015 at 5:57 PM
    #2056
    millertime89
    Erik
    Saskatchewan
    Yes sir
    That was a very un-EAF comment... Gotta stay positive here.
    dakotasyota and 2ndGenJonny like this.
  17. Aug 12, 2015 at 5:59 PM
    #2057
    loco
    Phil
    Virginia Beach, VA
    Fucking Hater.
    SACTOWN likes this.
  18. Aug 12, 2015 at 6:02 PM
    #2058
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    That's something a WEAF owner would say.
    dakotasyota likes this.
  19. Aug 12, 2015 at 6:06 PM
    #2059
    weldo
    Pittsburgh, pa
    WEAF as in We Expect Assloads of Fine-ass boobies!
    dakotasyota, SACTOWN and Acerwin like this.
  20. Aug 12, 2015 at 6:12 PM
    #2060
    weldo
    Pittsburgh, pa
    Seriously, this build has made more progress in 3 months than many make in years. Even with all the set backs and repairs. Truck looks awesome, when it's done it's gonna be all like...
    dakotasyota, Acerwin and 2ndGenJonny like this.
