Loctite
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SeaPA, Jan 13, 2019.
  1. Jan 13, 2019 at 5:39 AM
    SeaPA
    SeaPA [OP] Well-Known Member
    NC
    2019 DCLB TRD OR 4x4
    Hi guys,
    I'm installing a bed step and predator steps today. Should I use locktite? If so which kind, red or blue?
    Thanks!
  2. Jan 13, 2019 at 5:42 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jan 13, 2019 at 5:44 AM
    SeaPA
    NC
    That's what I was thinking, thanks!
  4. Jan 13, 2019 at 5:50 AM
    SeaPA
    NC
    IDK for sure hence asking if I need it. Locktite creates a bond to hold the screws in that is strong enough to hold due to road vibration but can be broken when using hand tools to remove.
    No need to pay the dealership to install, you can do it yourself!
  5. Jan 13, 2019 at 7:05 AM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    i put mine on.
    it is fast to do, its just a few bolts. Grab some tools and just go somewhere else. Feel good about doing thing on the truck
  6. Jan 13, 2019 at 7:23 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I wouldn't put any . Rust is nature's version of loctite
    Yann, PeterMN, Big tall dave and 3 others like this.
  7. Jan 13, 2019 at 8:24 AM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Just go to a local Home Depot Walmart and stick them on.
    Boghog1 likes this.
  8. Jan 13, 2019 at 3:47 PM
    aaen
    Northern Alberta
    I’m serious, i’ve Don I numerous times in the parking lots of big chain stores. Have a friend come with you, use some jack stands, and voila. It’s a few bolts.
    Have an ace hardware, pep boy, o’reillys? They will usually let you as well
  9. Jan 13, 2019 at 4:03 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    As a rule, if a fastener is not going to be removed, and especially if it is subject to vibrations or the threading is sketchy, I Loctite it.
    jmneill likes this.
  10. Jan 14, 2019 at 12:56 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Red. Definitely red. :D
  11. Jan 14, 2019 at 1:05 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I'd say weld it on. That should do the trick.
    CusterFan and la0d0g[QUOTED] like this.
  12. Jan 14, 2019 at 2:38 PM
    SlapChop7
    SlapChop7 Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    I just used red loctite for wheel spacers. Prolly F’d up but it was too late before I realized I was supposed to use blue :facepalm:
    CusterFan likes this.
  13. Jan 14, 2019 at 4:05 PM
    aaen
    Northern Alberta
    You’ll need a lot of heat on it to break the red, and don’t be surprised if the stud breaks off. Red is seriously strong stuff
  14. Jan 14, 2019 at 4:14 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    How long does it take for red to cure? Depending on when he installed it may not be too late.
  15. Jan 14, 2019 at 4:15 PM
    SlapChop7
    Eastern NC
    Guess I’ll be buying a torch when it comes time to remove them. :notsure:
  16. Jan 14, 2019 at 4:15 PM
    SlapChop7
    Eastern NC
    Ten minutes I think. Installed about an hour ago.
  17. Jan 14, 2019 at 4:17 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Oof. I'd probably give it a shot since it's still pretty fresh.
  18. Jan 18, 2019 at 3:18 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    No need for Loctite. The bolts have yellow Loctite on them already.
    Had mine installed today and these folding bed steps are the best thing to come along since sliced bread. Highly recommend them.
  19. Jan 18, 2019 at 3:55 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    That link above says fully cured in 24hrs- I’d take care of it now if I were you. Easier fix now or well youll be kicking yourself later… just saying
  20. Feb 11, 2019 at 8:32 AM
    ChasVS
    ChasVS Well-Known Member
    2017 Tacoma ACLB TRD Off Road
    Put one on mnie 2 years ago and took it off last week as I'm trading the 'taco in. Was still tight as when installed so don't seat the Locktite you used!
